FITTING STRUTBRACE?????????
Just got my sparco strutbrace ive offered it up to the car but it hits the heater box
what do i have to do to make it fit??
,cheers
....btw its a s2erst
just use a bit of force thats all, it looks like it aint gonna fit but when you pop in on n it sits in place its ok
just push the heater box back to get it on the let the heatewr box rest back against it
If you don't make a cut-out, then the airbox seal will not sit properly against the bonnet vent. And it will look gash. Do it right mate, and make the cut-out so that it all sits correctly with no stresses on parts
No, just take the top seal off and unclip the front of the surround via the metal clips on each end.
I used a hacksaw blade to cut it. It's quite thick, so a stanley blade will not do it. Fit your strut brace with the cover off, then keep trial fitting the cover until it fits back in nicely without too much hassle.
marky_g
Aug 15, 2015 10:43 AM
track.focus'd
Aug 12, 2015 05:53 PM
