sierra ENGINE CONVERSION !
Old Mar 28, 2006 | 06:49 AM
tizer's Avatar
tizer
Default sierra ENGINE CONVERSION !
i have a 90' sapphire cosworth replica > with a ridiculously mint body shell & interior ! but is fitted with a nasty oil burner of a 1.8 CVH >
i need somebody iwth some experience / knowledge to point me in the right direction as what to do with the power-plant e.g
what could be wrong with the cvh > burning oil "heavy smoke" above 4000rpm ! > is it worth fixing ?
zetec conversion > 1.8 / 2.0 zetec > even the i4 RS2000 engine > has this been done b4 ? and if so how hard of a job is it > prices etc... i've seen zetec's in fiesta's / escort's but never in a sierra !
an RS turbo engine ! > is this a direct replacement ? what difficulty's will i heave with the loom > and petrol tank etc ???
a large capacity 2.8 / 2.9 ? xr4x4 > is it feasable to convert to 4wd ? is this cost effective and a simple job?
i'm on a tight budget > but it's such a shame to let this car down with a nasty engine !
"cosworth is a NO NO" > insurance & cost put a stop to that !
any help / info / parts offered ... much apprecaited ! cheeRS simon
Old Mar 28, 2006 | 11:37 AM
jonnyturbo's Avatar
jonnyturbo
right the cvh is probably smoking due to worn valve stem seals, not that big a job, but it could also be piston rings or bores if there is constant smoke at higher revs. not worth fixing really.
as for engine transplant, an rs turbo, rs2000 engine are going to be a lot of hassle and money to fit and get running on your saph.
if i was you, i would source an xr4i and swap the engine, loom, petrol tank, gearbox, etc. straight swap, and a lot more fun than the shonky 1.8.
best thing is there are lots of tuning parts still easily available for the 2.8/9. stick with RWD lots more fun than 4WD
Old Mar 28, 2006 | 12:13 PM
tizer's Avatar
tizer
i've been offerd a 2.3 pinto turbo ? all ancillaries box is this an easier instalation >>>
as i know alot of sierra's were fitted with the pinto engine !
Old Mar 30, 2006 | 09:51 AM
tizer's Avatar
tizer
bttt > getting another 1.8 fitted to keep it on the road > but really wanting a 2.9 RWD conversion now !
anyone know of any part's car's 4 sale in the AREA ?
Old Apr 4, 2006 | 06:16 PM
opposite lock's Avatar
opposite lock
go and find a nice 2nd hand v8 , rover , chevy !! . loads of torque n power and quite cheap. Otherwise id pay the extra and stick a 24v cossie motor in. Sound awsome end of....
Old Apr 4, 2006 | 06:17 PM
opposite lock
i meant pay the extra insurance fee , it,ll be worth it. Greenlight will give you a good quote mate
Old Apr 4, 2006 | 06:33 PM
rumba2006's Avatar
rumba2006
2.0 litre zetec it m8 you have the 1.8 cvh running gear it should'nt be that hard to bolt it all up. it should be a bolt in replacement on your 1.8cvh you just need to sort the clutch out which uses a combo of your clutch and 1.8 cvh flywheel *I think* the zetec engine loom\brain is seperate from the main focus\mondeo loom it just needs splicing into your 1.8 cvh loom
check this out for RWD zetec applications.
http://www.spydercars.co.uk/practica..._feb05_pg1.htm
Old Apr 5, 2006 | 10:25 AM
foreigneRS's Avatar
foreigneRS
Testing the future
personally i would go for a 2.0i OHC from a sierra. get the head skimmed and port it and fit the high torque cam for the injection injection and you'll have a lovely torquey motor that will be about 120 bhp with a free flow filter and exhaust
Old Apr 6, 2006 | 05:40 PM
rumba2006's Avatar
rumba2006
2.0 zetec is 130 bhp in standard form,
then follow this to fit into your car
http://www.gibbs111.fsnet.co.uk/eng_gear_comb.htm
SmudgerByName
52
Jul 28, 2016 06:14 PM
Toms Grende
13
Aug 22, 2015 03:39 PM
Vincereese
Aug 15, 2015 06:24 PM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
