turbo or supercharger
Old Mar 25, 2006 | 08:10 PM
morto's Avatar
morto
Default turbo or supercharger
just readin on the how it works site, was never to sure how the supercharger works , great read tho
Supercharger Advantages
The biggest advantage of having a supercharger is the increased horsepower. Attach a supercharger to an otherwise normal car or truck, and it will behave like a vehicle with a larger, more powerful engine.
But what if someone is trying to decide between a supercharger and a turbocharger? This question is hotly debated by auto engineers and car enthusiasts, but in general, superchargers offer a few advantages over turbochargers.
Superchargers do not suffer lag -- a term used to describe how much time passes between the driver depressing the gas pedal and the engine's response. Turbochargers suffer from lag because it takes a few moments before the exhaust gases reach a velocity that is sufficient to drive the impeller/turbine. Superchargers have no lag time because they are driven directly by the crankshaft. Certain superchargers are more efficient at lower RPM, while others are more efficient at higher RPM. Roots and twin-screw superchargers, for example, provide more power at lower RPM. Centrifugal superchargers, which become more efficient as the impeller spins faster, provide more power at higher RPM.
Installing a turbocharger requires extensive modification of the exhaust system, but superchargers can be bolted to the top or side of the engine. That makes them cheaper to install and easier to service and maintain.
Finally, no special shutdown procedure is required with superchargers. Because they are not lubricated by engine oil, they can be shut down normally. Turbochargers must idle for about 30 seconds or so prior to shutdown so the lubricating oil has a chance to cool down. With that said, a good warm-up is important for superchargers, as they work most efficiently at normal operating temperatures.
Superchargers are common additions to the internal combustion engines of airplanes. This makes sense when you consider that airplanes spend most of their time at high altitudes, where significantly less oxygen is available for combustion. With the introduction of superchargers, airplanes were able to fly higher without losing engine performance.
here or the disadvantages..
The biggest disadvantage of superchargers is also their defining characteristic: Because the crankshaft drives them, they must steal some of the engine's horsepower. A supercharger can consume as much as 20 percent of an engine's total power output. But because a supercharger can generate as much as 46 percent additional horsepower, most think the trade-off is worth it.
Supercharging puts an added strain on the engine, which needs to be strong to handle the extra boost and bigger explosions. Most manufacturers account for this by specifying heavy-duty components when they design an engine intended for supercharged use. This makes the vehicle more expensive. Superchargers also cost more to maintain, and most manufacturers suggest high-octane premium-grade gas.
Despite their disadvantages, superchargers are still the most cost-effective way to increase horsepower. Superchargers can result in power increases of 50 to 100 percent, making them great for racing, towing heavy loads or just adding excitement to the typical driving experience.
andy
markk
Sep 9, 2015 08:11 AM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
