Painting cosworth cam cover
Either use a stanley blade or you can buy badges to go on your cover from fleabay ive just purchased a set and they are the nuts will post you a pic in a min
Doug .
Doug .
David there are no more listed at the moment but here is the guy's e-mail ask him he may sell you one direct ?
danb4444@btinternet.com
Regards Doug .
Regards Doug .
you will get best results from the milling machine, it will get it nice and flat and keep the edges sharp and well defined. Personally I hate seeing polished stuff with rounded edges, it's hard to avoid doing it by hand..
This is mine after i ran the flapper wheel across it. I have since smoothed it up with a rubbing block and it came up ok.
If your M8 will run the milling machine over it then id go that route
jessie_rs
11
03-06-2019 04:57 PM
JoeyBoyden
18-08-2015 10:52 PM
