no spark?
Old Mar 25, 2006 | 02:05 PM
rst in breaking's Avatar
rst in breaking
Default no spark?
i been completing a conversion my friend started ive got the engine turning over buti have no spark? the coil is connected to the dizzy all leads are on but no spark? any suggestions appreciated, cheers
Old Mar 25, 2006 | 08:10 PM
Versus_Creations's Avatar
Versus_Creations
Ask me a question!
If your converting a car and need help to start it god help the car when done.
Old Mar 25, 2006 | 09:31 PM
rst in breaking
i didnt start the conversion and ive never worked on a s2 before ive done virtually everything needed just wanted to know wot else if anything as i have coil wired,ignition,starter motor, dizzy earthed but no spark? its just a dummy car before i convert it but not ripping it apart dont help when im starting from scratch, and the looms been cut about so i need help correcting it, not stupid comments,if you can help appreciated
Old Mar 26, 2006 | 04:49 PM
SafeChav's Avatar
SafeChav
Well, to be honest, trying to fault find a conversion across the net more than likely never happens, like playing pin the tail on the donkey............could be anything and without offence, if you haven't worked on an S2 before, you may of done something wrong
Old Mar 28, 2006 | 04:35 PM
rst in breaking
sorted, there was a break in the power cable to the coil
DixieTheKid
11
Jun 6, 2020 11:20 AM
deathrider666
Sep 28, 2015 06:12 PM
pabloXR
Sep 21, 2015 12:42 PM
beller
Sep 21, 2015 04:13 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
