Little bit of help please with a vauxhall
Old Mar 25, 2006 | 01:28 PM
Rippers's Avatar
Rippers
Monte Geek
Default Little bit of help please with a vauxhall
My Bro in law has a m-reg corsa 1.0 and he has a few running issues.
It start and runs fine untill he has to stop where the engine starts searching and reving up and down... if he puts his foot down on the clutch the engine idles very low (as low as 200revs) and trys to stall.
Prob is he isn't local so any suggestions as to fixing this?
Cheers People
Old Mar 25, 2006 | 01:31 PM
the revving up and down sounds like the idle control valve needs cleaning
any noice with the clutch being pressed? (other than the change in engine note due to revs?)
Old Mar 25, 2006 | 01:33 PM
Rippers's Avatar
Rippers
Monte Geek
Just asked will get a reply in a sec
Old Mar 25, 2006 | 01:36 PM
Rippers's Avatar
Rippers
Monte Geek
He said he as heard nothing noticable when pressing the clutch
Old Mar 25, 2006 | 06:19 PM
Rippers's Avatar
Rippers
Monte Geek
Anymore for anymore
Old Mar 26, 2006 | 05:45 PM
jr's Avatar
jr
hmmm, they didnt actully make a 1.0 corsa untill the post 97 facelift came in iirc, which is the ecotech z10xe
as chip said, cleaning out the icv would be my firtst guess
Old Mar 26, 2006 | 06:12 PM
dan druff's Avatar
dan druff
on the 1.o corsa im sure the iac valve is a sealed plastic case and cant be cleaned internally .vauxhall advise modified iac motor and also reprogrammed engine software done with tech 2 .which is to stop stalling ,revving up etc
Old Mar 26, 2006 | 06:15 PM
Rippers's Avatar
Rippers
Monte Geek
its an S-reg
Cheers for the advise Dan druff I'll pass the info on
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
chowfornow
Sep 19, 2015 10:47 PM
