difference between t3 and t34
2wd saff on a stage 3 what difference will it make power/torque wise, i guess 320 max with the t3 but how much of a difference does a t34 make,is it worth the £450 ish to upgrade to one or not, going to stu's shortly and i dont know whether or not to get one before i get the conversion
if you have a .63 housing on the t34 then it makes it a bit more laggy but will put power upto around 350bhp and if you go to grey's later then it "can" go upto 430bhp on the same turbo
Russ Payne
Sep 25, 2015 08:29 PM
