nearly got the cossie running but need futher help......
first ov all i would like to say thanks to all the ppl who have been helpin me on here.
i have nearly got to the bottom of this now. but i am still not getting a spark on my cossie.
my phase sensor and crank sensor seem to be fine. i am getting fuel up now too.
I have done a check on the coil side of things by linking pins 24 and 25 this energizes the coil manually, which it does i get a spark right the way through to the plug.
BUT when i turn the car with the key there is no spark, now i need to know what the fooook tells the ecu to power up the coil. i assume the crank sensor does but i am stuck now....need help..lol
as i have done right the way through this prob
lem..haha
so i do get a spark but only when i link pins 24-25 out with out the ecu connected, but when i connect the ecc and turn it over with the key i dont get a spark, so this would mean that the dizzy rotor arm phase sensor is fine??!!!!!!
lem..hahaso i do get a spark but only when i link pins 24-25 out with out the ecu connected, but when i connect the ecc and turn it over with the key i dont get a spark, so this would mean that the dizzy rotor arm phase sensor is fine??!!!!!!
Karl 3dr
102
Oct 14, 2016 08:17 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Red_bull
Aug 9, 2015 08:34 AM
lockie
Jul 31, 2015 10:03 PM
