hall effect sensor
Old Mar 22, 2006 | 05:01 PM
cuvner's Avatar
cuvner
Default hall effect sensor
i was testing the thing on the car today and i see that there is a 12v input wen ignition is on, there is 3pins on the sensor + 0 -, so does the output voltage come out of the 0pin and go too the coil? my meter isnt designed to check a pulsing voltage as quick as that so i couldnt get a reading off the middle pin (marked "0"), just wana see there is still a 12v input and output wen my car cuts out , dam thing didnt cut out today did it!
Old Mar 22, 2006 | 05:07 PM
biglee's Avatar
biglee
Audio specialist
the sensor creates a very small voltage that goes to an ignition amplifier, then to the coil, these cars have problems with some pins becoming intermitant conections on the ecu, i would suggest firstly taking your ecu out and cleaning the pins with contact cleaner, se waht happens then mate. L
Old Mar 22, 2006 | 05:27 PM
Rick's Avatar
Rick
ignition amp is in the ECU
Old Mar 22, 2006 | 05:32 PM
cuvner's Avatar
cuvner
ok cheers
Old Mar 22, 2006 | 07:41 PM
DazC's Avatar
DazC
It'll probably be a 5v square wave which will need an oscilliscope to test properly...
Old Mar 22, 2006 | 07:52 PM
biglee's Avatar
biglee
Audio specialist
quite correct, its 2.4v +&- of 0v thus making 4.8v cosistant sqaure wave, if you dont have an osciliscope handy which not many ppl have, you can use(sounds weird) a scrap pair of walkman headphones....haha yes you can listen to the pulse... just connect the headpone bare wire to the + - connections, if it clicks constant in your ear if its workin properly...weird i know but when your in the middle of nowhere and trying to determin whats wrong with your motor.........it worked lol
Old Mar 22, 2006 | 07:57 PM
cuvner's Avatar
cuvner
got a dizzy coming in a few days hopefully this is where the problem lie's but ive bn trying to test the whole ignition circuit just incase the problem lie's somewhere else
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
