S2 gearbox
Old Mar 21, 2006 | 06:18 PM
sykes's Avatar
sykes
Default S2 gearbox
My gearbox in my s2 rst is on the way out and ive read somewhere of people using diesel van boxs and altering the mounts. From which mk van do I need the box from and which mounts do i need to alter?
Old Mar 21, 2006 | 06:25 PM
biglee's Avatar
biglee
Audio specialist
if you do this you will only need the mounts from your original rs box and the bolts, it all fits together ok.
but.. the diesel box is no stronger it just has longer gears, also it has NO limited slip diff,
the best option is to buy a recon rst box with better diff and shaft bearings and if you want the longer gears get a fith gear put in it from a diesel box. stay with the LSD tho...
Old Mar 21, 2006 | 06:28 PM
sykes's Avatar
sykes
Alrite cheers mate
Old Mar 21, 2006 | 06:53 PM
dave_y's Avatar
dave_y
get onto CTS, stage one box is only Ł500 exchange.
Old Mar 21, 2006 | 07:39 PM
Oranoco's Avatar
Oranoco
dave y beat me to it. The diesel box being tougher is an old wives tale. The only plus point is they are cheap.
CTS for a stage 1 box www.gearboxman.co.uk
Old Mar 21, 2006 | 08:14 PM
dave_y's Avatar
dave_y
im gonna ring CTS tomorrow but could anybody tell me how much they would charge to rebuild my current gearbox to stage 1 spec. would it be any cheaper since my gearbox is currently in perfect working order....
Old Mar 21, 2006 | 08:17 PM
adamS2RST's Avatar
adamS2RST
http://www.gearboxman.co.uk/psgearboxes.html - Ł495, that's minus the VAT I'd guess...it wont be any cheaper as they will be taking your box in exchange...
Old Mar 21, 2006 | 08:19 PM
DanRSturbo's Avatar
DanRSturbo
Can't fault the Stage 1 box
Old Mar 21, 2006 | 08:22 PM
dave_y's Avatar
dave_y
i suppose they would charge you a bit more than the 495 if your box was knackered then, durr i really should think!
Old Mar 21, 2006 | 08:25 PM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
Top advice, and what I would have said.
Old Mar 21, 2006 | 08:54 PM
biglee's Avatar
biglee
Audio specialist
why thankyou very much.
Old Mar 21, 2006 | 08:57 PM
DanRSturbo's Avatar
DanRSturbo
Mine was rattling quite badly when it went in there, came out sound as a pound
chowfornow
14
Jan 5, 2019 09:01 PM
mjonathan24
Oct 29, 2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
Iain Mac
Sep 30, 2015 09:39 PM
A.t.p
Sep 29, 2015 05:04 PM
