bleeding brakes.....
Old Mar 19, 2006 | 05:22 PM
B13 JUS's Avatar
B13 JUS
Default bleeding brakes.....
i've just fitted a new abs part that goes onto the passager side inner wing on my escort cosworth...
i started to bleed the brakes the front 1's are fine but can't get any fluid through the back 1's. when i loosen the bleed nipple on the back calipers the brake peddle won't go 2 the floor and no fluid will come out.
any ideas????
Old Mar 19, 2006 | 05:36 PM
foreigneRS's Avatar
foreigneRS
Testing the future
if it's like the sierra, you have to have the ignition switched on to 2 to bleed the rear brakes, as they are pressurised by the pump
Old Mar 19, 2006 | 05:50 PM
B13 JUS's Avatar
B13 JUS
cheers mate
Old Mar 19, 2006 | 06:05 PM
DangerousBryan's Avatar
DangerousBryan
you shouldn't have to pump the pedal.ignition on,bleed nipple open,press the pedal down slightly and the pump will push the fluid through for you . hey presto,bled brakes.
bryan
Chas
Oct 5, 2015 07:13 PM
kevin36
Sep 9, 2015 11:12 AM
markk
Sep 9, 2015 08:11 AM
kevin36
Sep 8, 2015 12:23 PM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
