Who does suspension setups in the southeast?
Old Mar 19, 2006 | 01:00 PM
Jim Galbally's Avatar
Jim Galbally
Default Who does suspension setups in the southeast?
ok im sure ive asked this loads of times but...
theres a place near me called GL Coachworks, i'm rining them tomorrow, but think theyll have a long waiting list, and i wanna get this set up ASAP.
i've got coilovers and adjustable TCAs, so nothing too major, but it needs setting up (especially now the TCAs are on! )
ta
Old Mar 19, 2006 | 01:01 PM
GARETH T's Avatar
GARETH T
what about a blit of DIY?
string the car up and see what you got
Old Mar 19, 2006 | 01:02 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Field Motorsport Jim
Old Mar 19, 2006 | 01:15 PM
Jim Galbally
gareth, i have NO idea what i'm doing, and none of the laser alighny and weighing equiptment.
radders, i'll give ema bell on monday
Old Mar 19, 2006 | 01:17 PM
Charlie Chalk
Unknown.
Old Mar 19, 2006 | 01:26 PM
sbd16v's Avatar
sbd16v
is danny b not around your area ???
Adrenaline Race & Performance Ltd 01933 315191
Old Mar 19, 2006 | 01:40 PM
Charlie Chalk
Unknown.
he's in Northampton, Jim's from kent
Old Mar 19, 2006 | 01:42 PM
sbd16v's Avatar
sbd16v
well its close same side of the country aint it
mines coming from plymouth to do to dannys
Jim Galbally
i'd consider dannyB to be "northern"
Old Mar 19, 2006 | 01:46 PM
Charlie Chalk
Unknown.
when is it going up there?
Dont mind me asking what your having done??
PM me if you like
Charlie Chalk
Unknown.
Old Mar 20, 2006 | 02:55 PM
Jim Galbally
spoke to field motorsport, they are £300, but thats for a pukka motorsport "dogs bollocks" kinda thing
i think its a little overkill for my road car.
i just need the ride height set so that the tyres dont point inwards and have the front wheels pointing straight!
Old Mar 20, 2006 | 03:06 PM
BillyCabrio's Avatar
BillyCabrio
Have you rung GL then?
Old Mar 20, 2006 | 03:16 PM
Jim Galbally
Gl can't do corner weighting etc.
but after rining around ive rung em back and they're doing it i'm gonna get liam to raise the coilovers up a bit (i'm going to BAR tomorrow morning to get my clutch cable swapped n fix an exhaust blow) so at least that bit will be better.
booked in at GL @ 5pm
Old Mar 20, 2006 | 03:18 PM
Charlie Chalk
Unknown.
Nice one Jim
Old Mar 20, 2006 | 04:01 PM
neilm's Avatar
neilm
Jim, you came as far as Bernie..
Northampton Motorsport are only a few more junctions up the M1 (J15)
Check the link to see what they can do for you.
http://www.northamptonmotorsport.com/default.asp?id=20
Prices start at £80+VAT
Old Mar 21, 2006 | 06:38 PM
Jim Galbally
just had mine done by GL coachworks:
the car now drives in a straight line
Old Mar 21, 2006 | 06:45 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
according to that printout you run 15's thought u had escort cossie rims there 16" aint they??
Old Mar 21, 2006 | 07:51 PM
Jim Galbally
no, its the computer saying the cosworth comes with 15s they put in the car type and it tells them the standard settings to adjust the car to
Old Mar 21, 2006 | 08:11 PM
BillyCabrio
Wicked!!
I gotta get some details off of TT before i get mine done
Old Mar 21, 2006 | 08:13 PM
Jim Galbally
if you can tell em what you want it set to then all the better
have you got compression struts on yours? if so they can do the caster n stuff n all mine was only camber+toe they could do.
by the way, is 3degree neg camber on the back a lot? it dodnt sound too bad to me... (thats if the readout is right for the back, he was only playin with the front)
Old Mar 21, 2006 | 09:06 PM
GUZZLER's Avatar
GUZZLER
one of the fella's at work is a bit handy 4 wheel alingment, we do loads of subarus that have had numerous visits to a kwik fit style place & never been done right, makes a car so much nicer to drive when its set up properly.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
SMILER258
Sep 28, 2015 09:04 AM
