2wd cos thernostat help needed car in bits!!
some one tell me where the thermostat goes please???
I thought it was inside the head as you look at the engine behind the bit where the top hose from the rad goes???
just took it off and there aint anything there at all and the thermostat doesnt seem to fit any where!!!
help please!!!!
cheers peeps
help please!!!!
cheers peeps
do you mean the bit thats got 88 stamped on it, same side as the spring??
and should it fit inside the housing?? it looks like it should fit right inside but the one i have dont fit inside???? the lip around the thermostat itself stops it from going right inside???
do i have the wrong one???
JoeyBoyden
Jan 4, 2024 02:36 PM
rog
Sep 4, 2015 12:10 PM
