HELP NEEDED ASAP: Toad immobiliser removal - ALL SORTED!
Old Mar 18, 2006 | 10:23 AM
andre_k's Avatar
andre_k
Default HELP NEEDED ASAP: Toad immobiliser removal - ALL SORTED!
my toad immobiliser fob on my s2 is knackered (i think it has been dropped, and the little chip inside has smashed), and i have been told it is irreparable and will need removing...
where would i start? chopping wires till it works? i have found the box, if you remove the heater vent near the ignition barrel its behind it.
need some help with removing it, as i need my car!
dre
Old Mar 18, 2006 | 10:25 AM
SPADGE's Avatar
SPADGE
Trace all the wires back and remove them mate BUT some of the existing wiring would have been cut and so will need joining again to create the original circuits!
Old Mar 18, 2006 | 10:26 AM
SPADGE's Avatar
SPADGE
Feel free to bell me anytime today if you get stuck
07718 901737
Old Mar 18, 2006 | 10:27 AM
andre_k's Avatar
andre_k
cheers spadge, nice one
should it be fairly simple to do?
Old Mar 18, 2006 | 10:30 AM
SPADGE's Avatar
SPADGE
Depends on the person who is trying to do it mate lol
Not a difficult job but does require a small amount of wiring nouse
Old Mar 18, 2006 | 10:34 AM
Spiky's Avatar
Spiky
make sure you solder the cables back together not those stupid scotch locks ro bullet connections, as some sire will have hire amp's going through them
Old Mar 18, 2006 | 10:35 AM
andre_k's Avatar
andre_k
ok, ill have a go in the next hour, and ill give you a bell if i get stuck
Old Mar 18, 2006 | 10:41 AM
andre_k's Avatar
andre_k
will the dash need removing?
Old Mar 18, 2006 | 12:00 PM
Damo V's Avatar
Damo V
Depends if it was removed to install, but yes as you arent sure may be a good idea..
Old Mar 18, 2006 | 12:03 PM
andre_k's Avatar
andre_k
but isnt dash removal on a s2 abit of a 'mare?
Old Mar 18, 2006 | 12:05 PM
Damo V's Avatar
Damo V
Half hour- hour job
Old Mar 18, 2006 | 12:06 PM
andre_k's Avatar
andre_k
really? that easy? neva done a dash before
Old Mar 18, 2006 | 12:08 PM
Damo V's Avatar
Damo V
ok maybe hour to 2 hour...
Do a search loadsa info on it
Old Mar 18, 2006 | 02:36 PM
andre_k's Avatar
andre_k
all done
took 1/2 hr to get running, im going to tidy it up tomorrow
thanks to spadge and damo for the help, mucho appreciated
dre
JoeyBoyden
Jan 4, 2024 02:36 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
Bosch
Aug 4, 2015 05:14 PM
