revs rising???
the idle on my frst has developed a mind of its own!?
At some points i'll pull up and the revs are sitting at nearly 2k, whereas other times it'l be fine, then it'll be 1.5k?
help!!!
help!!!
check the pipe off the inlet manifold to the brake servo as if this becomes loose in the fitment to the manifold it starts to do this and eventually comes out and you may as well have anti lag lol
mine did this and it was holding the revs up at 5k with the turbo chattering and etc lol was funny but not good as everything i did and wondered if i had fixed it ment i had to start the car from cold to it doing this :O
TPM961
Jan 15, 2018 10:50 AM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
