Quick piston/bore size question
hi all
got some new standard compresion OE replacement YB
mahle pistons in +0.5mm . but the box didnt have a new Bore
size on it.
can anyone help me out please!?
whats the new finished bore size gotta be
wanna get it all across to the engine shop today if i can
Thanks!
( just add 0.5 to the original size? ? but what is the original size lol)
size on it.
Thanks!
thanks mate!
dunno if they would all be the same?
the numbers on mine are as follows in pics:
the second pic is date, but unsure of the other numbers?
Mine are Mahle replacement set, so no OE part numbers, but Piston is marked with diameter size 91.275
so the difference between Cylinder bore size quoted and piston size is 91.325-91.275=0.05mm
so you can get the machine shop to measure the pistons and apply the same clearance i guess if there is any difference
Brilliant mate thankyou!
just measured the skirt of my new pistons
and it is 91.275 mm as well (no surprise there lol)
thanks, Just the info i needed
M J engineering in westbury-leigh
i believe Cossiedave and SECS simon go there too
martin over there is a nice guy,, but VERY busy at the mo lol!
andrewmctiernan
Sep 8, 2015 03:05 PM
