Quick piston/bore size question
Old Mar 18, 2006 | 07:16 AM
pee vee's Avatar
pee vee
Default Quick piston/bore size question
hi all
got some new standard compresion OE replacement YB
mahle pistons in +0.5mm . but the box didnt have a new Bore
size on it.
can anyone help me out please!?
whats the new finished bore size gotta be
wanna get it all across to the engine shop today if i can
Thanks!
( just add 0.5 to the original size? ? but what is the original size lol)
Old Mar 18, 2006 | 07:28 AM
richm's Avatar
richm
I got a box of 0.5mm Mahles here, part number 0149101 , 91.325mm cylinder diameter is quoted on the box.
Old Mar 18, 2006 | 07:36 AM
pee vee's Avatar
pee vee
thanks mate!
dunno if they would all be the same?
the numbers on mine are as follows in pics:
the second pic is date, but unsure of the other numbers?
Old Mar 18, 2006 | 08:00 AM
richm's Avatar
richm
Mine are Mahle replacement set, so no OE part numbers, but Piston is marked with diameter size 91.275
so the difference between Cylinder bore size quoted and piston size is 91.325-91.275=0.05mm
so you can get the machine shop to measure the pistons and apply the same clearance i guess if there is any difference
Old Mar 18, 2006 | 08:03 AM
pee vee's Avatar
pee vee
Brilliant mate thankyou!
just measured the skirt of my new pistons
and it is 91.275 mm as well (no surprise there lol)
thanks, Just the info i needed
Old Mar 18, 2006 | 08:27 AM
richm's Avatar
richm
Where do you go for your machining Phil?
Old Mar 18, 2006 | 08:30 AM
pee vee's Avatar
pee vee
M J engineering in westbury-leigh
i believe Cossiedave and SECS simon go there too
martin over there is a nice guy,, but VERY busy at the mo lol!
Old Mar 18, 2006 | 08:59 AM
richm's Avatar
richm
ah cool.. yeah i had my head done there last year, did a nice job.
alexbarnes95
11
Sep 15, 2015 10:26 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
Bransby
Sep 11, 2015 01:09 AM
andrewmctiernan
Sep 8, 2015 03:05 PM
