S1 RS Turbo Spot Lights
Old Mar 14, 2006 | 09:00 AM
C0S_TURBO's Avatar
C0S_TURBO
Default S1 RS Turbo Spot Lights
The spot lights on my S1 have decided they are not going to work any more. I have changed both bulds, still no joy, if I use a multimeter it shows there is over 12 volts there with the engine running and the lights on full beam. When I put the bulb back in the circuit the multimeter reads 0 volts or lo. Could it be a bad earth, if so were are the spot lights earthed.
Thanks
Old Mar 14, 2006 | 04:12 PM
James Raby's Avatar
James Raby
there should be an obvious cable that runs into the engine bay, follow this and it will come to a connection, just unplugs
i would chase the wires back to see if it's corroded or the ends just gone woooooopsi
Old Mar 15, 2006 | 01:21 PM
C0S_TURBO's Avatar
C0S_TURBO
I have chased them back and cleaned up the connectors, but haven't been unable to find the earth. There is an earth nead the wiper motor, but I can't find 1 near the spot lights or head lights.
Thanks
Old Mar 15, 2006 | 01:27 PM
Combi_Chris's Avatar
Combi_Chris
replace the earth , id rewire them totally if that was my car , how olds the wiring thats on there already ?
Old Mar 16, 2006 | 10:30 AM
C0S_TURBO's Avatar
C0S_TURBO
Last night for no reason what so ever they started to work after flashing someone to let them pull out????? Strange!
Old Mar 16, 2006 | 12:01 PM
SafeChav's Avatar
SafeChav
The earth is connected in with each headlamps earth, which drops down to its respective chassis rail. You will see an odd brown wire on its own screwed up. If the headlights are working i doubt very much you have lost an earth, especially if neither work as that means u would have to lose both the earths on either side of the car. Have you checked the relay? And have you continuity tested the earths?
Matt Baxter
Sep 16, 2015 08:30 PM
Sjieter
Aug 5, 2015 09:47 PM
cossiestu
Was It You?
Aug 2, 2015 02:49 PM
adriansaleem
Aug 1, 2015 09:28 PM
turbobill
Aug 1, 2015 08:55 PM
