Turbo Technics
Old Mar 12, 2006 | 08:39 PM
motherhupit's Avatar
motherhupit
Default Turbo Technics
Would a Turbo Technics Kit run rubbish on my car fiesta mk3 1600 sport CVH, TLD, Standard Cam , Flowed Head. but the problem is i had a 30tho skim to increase compresstion. would it run propally or would the skim bugger it up cheers BAZ and how much HP would i be looking at about 20 -25hp
Old Mar 12, 2006 | 08:51 PM
Rick's Avatar
Rick
would be fine. not really worth it unless u have one cheap etc. Will get about 30hp, but a shit load of torque.
Old Mar 12, 2006 | 08:56 PM
motherhupit
might consider it then either that or twin thorties, i have seen a cheap ish kit but the turbo has a bit of play side ways is this normal.
Old Mar 12, 2006 | 09:24 PM
motherhupit
Also how would i go about making a oil feed and oil re-turn and how hard would it be.
Old Mar 12, 2006 | 11:08 PM
FastFordChris's Avatar
FastFordChris
might be easier just going for an rst lump as finding a complete tt kit is very rare and even if you do it'll need a full referb. might be worth keeping your eye on ebay for a complete xr2-tt then you can swap all the bits over you need as its all there and you can sell the bits you dont need.
there cool little kits though deffernatly an option if you want to try something different.
Old Mar 13, 2006 | 07:01 AM
motherhupit
i've found a complete kit just need to know about turbo play and oild feed return. cheers guys
Old Mar 13, 2006 | 08:00 AM
Jim Galbally's Avatar
Jim Galbally
oil return is easy, you ust makea hole in the sump (altho on CVHes there may already be a hole inthe block you can use!
as for turbo play, on any TT kit you buy, budget for a rebuild of the turbo, most of them have seen better days
i'd also advise going the RST route, it'll be cheaper, give more power, more tuning potential, and a lot lot safer. you can do thw ehole swap in a day, maybe 2 if you're lazy and not done it before.
Old Mar 14, 2006 | 04:09 PM
motherhupit
Didn't buy it anyway guys was seriously thinking about it thow, yeah gonna do the FRST thing in 7 months anyway gonna buy a mint one for about 3k and swape the bits over from my car i got now only a few things like Black dash and Si doorcards, Think i'll sell my flush boot with the car and get a better one for the FRST i want it to be perfect nothing wrong or half attempted. so probally start a lot from scrath actually.
Old Mar 14, 2006 | 04:29 PM
luke89's Avatar
luke89
Team HOTHOT!
just build a nice lump for your car like a zetec turbo
Old Mar 14, 2006 | 06:20 PM
Fiecos Dan's Avatar
Fiecos Dan
a well set up tt, on a high comp 1.6 with std internals (as long as good running order)
will see 150-170 bhp and 190lb/ft (matters on boost etc etc)
Old Mar 14, 2006 | 07:27 PM
Jim Galbally
yeah but a bog standard RST with a chip and a -31 will see that too
Old Mar 14, 2006 | 08:04 PM
Fiecos Dan's Avatar
Fiecos Dan
he asked about a tt conversion,
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
Shows & Track Days
Sep 4, 2015 07:16 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
