ERST injector lines....
has anyone got a pic of an engine bay that shows where all the injector lines connect????
Changed the engine in mine over the weekend and the bugger wont start!
We think its possibly injector lines in the wrong way.....
CheeRS.
CheeRS.
The KE fuel system can air lock. It's more likely to be this. Crack all the banjo fittings off for the injector pipes and crank it over (or bridge the fuel pump relay out) until all the air stops coming out of the metering unit. Then nip the banjo bolts back up...
Be aware that there will be a lot of fuel dripping onto the floor though so make sure any scummy bastard smokers are nowhere near your car...
mk3ste
Oct 17, 2021 10:09 AM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mc5506
Oct 5, 2015 09:57 PM
