LHD 4x4 Steering rack
Old Mar 12, 2006 | 03:40 AM
robrs2's Avatar
robrs2
Default LHD 4x4 Steering rack
I'm in the middle of fitting a 2.9 24v cossie into my LHD 3door. But the problem i came across was fitting a 4x4 crossmember in palce of the 2wd one. Does anyone know where i'll get a power steering rack for the LHD 4x4 in the UK
I've seen some group A racks but at £700 they are way out of my price range.
Rob
Old Mar 12, 2006 | 05:31 PM
svony's Avatar
svony
You just missed this by a few days mate...
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEDW%3AIT&rd=1
Old Mar 13, 2006 | 07:25 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i may be able to source something from germany for you.
how much of a hurry are you in?
Old Mar 13, 2006 | 10:43 AM
robrs2's Avatar
robrs2
I'm in no hurry for it now as i have a 2wd sump to fit the engine for now so i can use the 2wd crossmember for now. If you find one cheap let me know thanks.
Rob
Old Mar 16, 2006 | 03:34 PM
foreigneRS's Avatar
foreigneRS
Testing the future
OK, so why do you want to fit a 4x4 cross member and rack?
Old Mar 16, 2006 | 05:53 PM
robrs2's Avatar
robrs2
The 4x4 crossmember is light than the steel 2wd one. Also at some piont i want to try the car with 4wd.
Old Mar 16, 2006 | 07:12 PM
foreigneRS's Avatar
foreigneRS
Testing the future
you're right, it is. it's stronger in some ways as well. i'd leave it rwd, but that's just my preference
i'll be in touch with a mate in germany, and see what he can do. can it be any 4x4 sierra? there were quite a lot of 2.0 DOHC models over there, but not so many v6's (although i had one, my estate that is now cossie powered and rwd - and i gave the complete running gear away to turboflush off here)
Old Mar 16, 2006 | 08:17 PM
PAUL S's Avatar
PAUL S
The cosworth rack has a ratio of 2.4 turns lock to lock where as all other 4x4 have a bigger 2.8 lock
I have a Cosworth 4x4 LHD rack in my garage - only problem is that its been stripped to fit new seals - any good to you in bits ??? easy enough to build back up if you have a manual
Old Mar 17, 2006 | 08:36 AM
foreigneRS's Avatar
foreigneRS
Testing the future
a.k.a
good point
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Iain Mac
Sep 30, 2015 09:39 PM
