one for the CVH gods
i found out today that series one, series 2 and fiesta turbos all have different pistons. but the same rings.
i had a series 2 and a frst piston together today and noticed a few differences. the series 2 has a larger crown and deeper valve cut outs.
my question to you is could you use erst pistons in a frst block?
i dont have a micrometer so i couldnt measure from the top of the piston to the bottom of the rod on each to compare them.
just from seeing the larger crown on the erst piston i thought if you put that in the frst block would it increase the compression ratio?
also just wondering, do erst and frst engine have the same compression ratio?
So no then
We looked at mixing them then quickly came to our senses as it was silly to work out the comp ratio etc... as they also had different rods in them etc...
Still sorted now cheers cowboi
My effing back hurts though
Ginge whats up?
Ginge whats up?
just been talkin about ur engine. probably best to turn the boost down a bit and try to keep the car running till u build the zetec. i cant be arsed doing it again this year. haha
cheers ginge but pretty much sorted. ill tell you my reasoning why tomorrow but ill be replacing the piston before anything else, the botton end is a good'un
Who suggested that cowboi and why?
mk3ste
Oct 17, 2021 10:09 AM
