when using a decomp plate ??
formerly beefy-rst-2
do i use 2 head gaskets , or seal the plate to the block or just fit it flat
if i have to seal it what should i use peeps
anyone got any info in this or anyone running on , info would be appriceated
thanks
beef
thanks
beef
more its the cheapest option bud , just need the car going and got 90 percent of the parts together ,
in a perfect world ive have a new set of low comp pistons but , on budget at mo
what would u use to seal it ???
Felpro make a product called 'brush tack' liquid gasket sealer.
put that on the deck surface followed by the plate, lastly the gasket.
Finally IMO one of the best tenners you can spend when doing
these kind of jobs is Snap On tool No FAM8E for your head bolts/
cos they NEVER slip or chew the hex and allow you to torque
the head down correctly.
lol , tried to ring colin at mad for it , number not in use at the mo
have to try and find some of that "brush tack "
mates got that snap on part already bud !!
just a cuple of bits to do now ,
still need to find a cheap turbo ,
rember im on budget lol
thanks for help guys
Originally Posted by ivorbiggun
There's no replacement for displacement...
remember your budget when it goes tits up and you have to do it all over again.......false economy my friend.
i would seriously seek the advice of a pro and take it from there.
rs turbos are not to be run on a tight budget let alone modified on one
appriceate what u posted guys ,
but why the heel do they make them and why do people use them if the re soooooo unreliable ???
, ant i aint going for masses of horepower , just need the car running ,
boost wont even be getting turned up ,
be left as standard
now any comments on the subject or we gonna start blabbing on about how much they cost cos belive me i know !!!!!
be left as standard
rick mate ,
already had the 1.8 motor in the garage , and 90 percent of the other bits needed bud ,
so far its set me back about 80 quid in bits and peices to get it where i can get it in the car and runnin ,
my cvh motors goosed ,
needs a full overhaul regrind shells rings pumps ect ect ,
looking at least 500 sheets to get that sorted ,
and when i get working again then , a propperly specced +built engine will follow ,
and seeing as im at the point now where its nearly done apart for a cpl little things ,
it will just have to go in and c how it does now wont it boys . !!!
howayyy the boro !!!
