DUMPVALVE PROBLEMS????
Old Mar 7, 2006 | 04:24 PM
COSSIE 1's Avatar
COSSIE 1
Default DUMPVALVE PROBLEMS????
Just fitted a dumpvalve 2 my s2erst ive got a samco hose with the dumpvalve takeoff and not the alloy tpiece lumbed it all in with a bailey piston dumpvalve splicedinto the vacumm hose on the right hand side and it wont idle at all it starts then cuts out, now i was lea to believe the idle would be crap, bu it doesnt idle whatsoever , now most of u will say take it off bt thats not the answer im after, any ideas whats causing this is it a faulty dumpvalveor something else.ideas please .p.s ive taken it of for now and plugged the hole and its fine........but i want to put one back on
Old Mar 7, 2006 | 04:27 PM
SafeChav's Avatar
SafeChav
What dump valve have you got. Sounds like you've got a diaphram dump valve, u need a twin piston dump valve on a ERST.
Old Mar 7, 2006 | 04:38 PM
addiction's Avatar
addiction
As Safechav says,its got to be a Bailey twin piston dump valve to work properly! and there is NO reason why you should have bad idle with it fitted! it makes NO difference to mine on idle when its on as to when its off!!
Old Mar 7, 2006 | 04:52 PM
Stu @ M Developments's Avatar
PassionFords Creator
Doesnt have to be a Bailey one at all, can be ANY twin piston dump valve.
Old Mar 7, 2006 | 04:56 PM
SafeChav's Avatar
SafeChav
Agreed Rumour has it the bailey one is the best if you insist on one however.
Old Mar 7, 2006 | 05:09 PM
Paul17's Avatar
Paul17
sounds to me like you've got some sort of air leak, this happened to me and it was a air leak. it's something to do with the flap underneith the airfilter. air is been sucked in and it's not passin through the flap
Old Mar 7, 2006 | 05:10 PM
COSSIE 1's Avatar
COSSIE 1
the dumpvalve ive got is a baileys piston type not sure if its a twin piston one r not, ive just got of the phone to woodford garage and they sell a dv26 for £69.95 so ill wack this on ebay and get oneof those.........which vacumm hose is best for the dumpvalve??..............i only paid £40 for the valve and the samco which is a bargain in my eyes , so im not bitter..lol
Old Mar 7, 2006 | 05:12 PM
COSSIE 1's Avatar
COSSIE 1
paul17....no airlek matey it was fine b4 i fitted the d/v and ive taken it of and plugged the d/v hole and its ok
Old Mar 7, 2006 | 05:19 PM
SafeChav's Avatar
SafeChav
Have a look down the end of the dump valve and if its twin piston u will see a thin metal piston inside a larger black plastic piston.
Any piping is ok, but we all know silicon vacuum hose looks the nuts The norm is about £10 for 3 metres, and small cable ties are the best way of securing the pipe onto conncetions (and if u really want to be a tart u can buy some matching coloured ones )
Old Mar 7, 2006 | 06:15 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
I've got a dumpvalve which i don't even use mate, doesn't look too mint but works fine, has had a big scratch on one side...if your not an engine bay blinger you can have it for alot less than £70
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
