I want a softer ride!
Old Mar 7, 2006 | 02:12 PM
Rick's Avatar
Rick
Default I want a softer ride!
My suspension is getting worse, im sure - or im getting old.
It's just too bumpy, and crashes into pot holes. The stability is fine, and the grip, just the ride is bad. I'm on Monroe gas shocks, and -25mm Pi springs - which i think are probably the problem. The rear end is on it's arse, think the springs have collapsed. Now, do i try some other springs, or, maybe go for some Koni's on soft as well?
Old Mar 7, 2006 | 02:36 PM
adamS2RST's Avatar
adamS2RST
I've got pretty much exactly the same problem Rick. I run PI shocks and -25mm PI springs. TBH the ride is awful, one of the front shocks was fooked in under a year (with about 2K miles driving)
I think I am personally going to go for a set of Koni's and some decent springs. I've heard Eibach are supposed to be good?
Old Mar 7, 2006 | 02:50 PM
Rick's Avatar
Rick
i have monroe shocks, which ive been out in other cars, and the ride has been spot on. i think it's the pi springs that are shit. Eibach are meant to be good, yes, but in what way? Good for track? Or a good ride?
Old Mar 7, 2006 | 03:11 PM
adamS2RST's Avatar
adamS2RST
I think you are right. I had to send a set of the springs back as they just were crap and made the car sit very strange! I got another set FOC which improved that but then the shock went anyway.... And regarding Eibach, that I don't know...I just seem to remember Christian mention it before.
Old Mar 7, 2006 | 03:19 PM
Rick's Avatar
Rick
Christian runs Cobra springs. Manchester Mike has put them on his car with koni's. Ive been out in it, and it feels ok, but really need to drive it and see. Just around town/low speed.
Old Mar 7, 2006 | 03:24 PM
adamS2RST's Avatar
adamS2RST
Then scrap that, I must have heard it elsewhere - But it's one of the next things I want to sort on my car so interested on people's views. The general consensus from a thread I started last time is here: https://passionford.com/forum/viewtopic.php?t=129113
Old Mar 7, 2006 | 03:34 PM
James Raby's Avatar
James Raby
I used to have Eibach springs, changed em to Cobra though on Christian's advise - probably cos I paid for em
I would suggest NOT having poly shock top front mounts though, this is one of the many reasons the car CRASHES into tiny tiny holes you would not feel otherwise...
What about the Ford aftermarket kit sold at shows?
Old Mar 7, 2006 | 04:12 PM
adamS2RST's Avatar
adamS2RST
I didn't know that...I have some of those to fit too...lol
Old Mar 7, 2006 | 04:15 PM
Rick's Avatar
Rick
i did - they are horrible
Old Mar 7, 2006 | 04:20 PM
Tony Turbo's Avatar
Tony Turbo
www.ctuceilings.co.uk
I have tried and tried, and I cannot think of anything funny to add to this topic, so I am just going to let you guys get on with it
Old Mar 7, 2006 | 04:43 PM
James Raby's Avatar
James Raby
Lucky I didn;t get them then innit'!!
Tony - you ALWAYS have something funny to add, are you feeling ill today
Old Mar 7, 2006 | 04:47 PM
SafeChav's Avatar
SafeChav
"Shocking"
No pun intended
Old Mar 7, 2006 | 04:56 PM
James Raby's Avatar
James Raby
'Boom Boom!' lol
Old Mar 7, 2006 | 04:57 PM
SafeChav's Avatar
SafeChav
Old Mar 7, 2006 | 05:03 PM
Hatch's Avatar
Hatch
Default Re: I want a softer ride!
know how you feel im on the wrong side of thirty , tell you what works for me on my S1 is standard ford shockys and eihbach springs as the standard shockys are pretty firm / firm enough and the springs just lower it a touch
Old Mar 7, 2006 | 09:28 PM
DazC's Avatar
DazC
Rick, you wouldn't like my car then. Mine is quite hard (suspension that is)!!!!
Old Mar 7, 2006 | 10:04 PM
NUTS RuS's Avatar
NUTS RuS
What profile tyres are you running you old fart
Old Mar 7, 2006 | 11:02 PM
Rick's Avatar
Rick
40 series
But, they are 215's so quite wide, they are no different from the std 195's ride wise - certainly a million times better than 17's.
Think i need to sack of these Pi(le of shit) springs. But what to go for? Eibach's, Jamex, chassis dynamics, spax, cobra's etc etc....
Got some new sensatracks in the cellar too.
Old Mar 8, 2006 | 12:14 AM
NUTS RuS's Avatar
NUTS RuS
Then get the sensatracs on first IMHO.
If you could disconnect the dampers and drive it down the road you would soon change your mind that the springs are too stiff lol
The sensortracs are also gas filled but the rebound will be better/fresher than on the old strut. Take one off and compare it (the rebound) side by side.
Or sit on a cushion
SMILER258
Sep 28, 2015 09:04 AM
marky_g
49
Sep 22, 2015 09:59 PM
Davemurphy007
Motorcycle Chat & Sales
Aug 14, 2015 05:58 PM
