Missfire...
Old Mar 7, 2006 | 09:15 AM
p_jay78's Avatar
p_jay78
Default Missfire...
Hello readers...
My stage 3 sapphire cosworth is getting misfire on full throttle through most of the gears....its running about 22psi of boost through a T34.
Think this might be plugs/leads? I wouldn't have thought it's over boosting at 22psi?
Any ideas anyone?
Old Mar 7, 2006 | 02:15 PM
KSA-Cossie's Avatar
KSA-Cossie
What plugs and gap are you running ?
Old Mar 7, 2006 | 02:19 PM
p_jay78's Avatar
p_jay78
I have no idea....
i've already got the RS specialist near me on the case and they're gonna wack some new plugs in. They think that the plugs are more than likely the cause?
Old Mar 7, 2006 | 02:48 PM
KSA-Cossie's Avatar
KSA-Cossie
Best place for it then.
Old Mar 7, 2006 | 09:38 PM
twitchyrear's Avatar
twitchyrear
normally the plugs,mine last about 2000 miles,then it starts to miss so i change them and prob solved
Old Mar 8, 2006 | 12:41 AM
cossy2wd's Avatar
cossy2wd
same as above they dont last that long
Old Mar 8, 2006 | 08:03 AM
AlexD's Avatar
AlexD
Post Miester !
I would say deffo Plugs tbh...
Al....
Old Mar 8, 2006 | 08:07 AM
p_jay78's Avatar
p_jay78
Hopefully you're right...
I've had a few teething troubles. I'm thinking about putting an Alfa Romeo badge on it!
In all fairness it has been sat for a year
Old Mar 10, 2006 | 08:19 AM
BMEP's Avatar
BMEP
Give your car a run on low boost (say 12-15psi) and see if the misfire disappears. If it does then it is a good indication that the plugs or leads are at fault.
Old Mar 10, 2006 | 08:31 AM
p_jay78's Avatar
p_jay78
I've noticed that if I don't floor it and use the power Conservatively it doesn't do it... but if I put my foot to the floor (so tempting in a cossie huh) it missfires and goes nowhere fast!
Its having new plugs put in tomorrow so hopefully that should sort it
At idle the engine is quite lumpy and rough - not sure if that is related?
Old Mar 11, 2006 | 08:02 AM
KSA-Cossie's Avatar
KSA-Cossie
Deffo the plugs then m8,keep us posted.
Old Mar 13, 2006 | 06:36 AM
p_jay78's Avatar
p_jay78
Yep it was the plugs...its now purring like a pussy cat
Power is smooth all the way through. Much smoother idle too!
Old Mar 23, 2006 | 11:57 AM
TurboShed's Avatar
TurboShed
Cossiemodo
Hi, this thread looks interesting...
Basically, could plugs in a Stage 3 Cossie wear out in say 100-200 miles, if it was REALLY thrashed?
Old Mar 23, 2006 | 12:27 PM
_DAN_'s Avatar
_DAN_
Yoon
(keeps eye on thread)
Old Mar 23, 2006 | 05:19 PM
Tor @ Racefix Motorsport's Avatar
Put new plugs in gapped @ 0,5mm, change your coil for a GpA one and have the fuel filter changed and fuel pressure reset. That`ll most probably solve your problem.
Old Mar 23, 2006 | 05:48 PM
vinnyd's Avatar
vinnyd
i know this migh sound stupid, but i have the same problem on mine when its running..lol
and its the fuel gauge it says its 1/4 full but really its low on fuel which makes it miss fire on high revs..
but it will prob be the plugs or leads..
Old Mar 24, 2006 | 12:06 PM
TurboShed's Avatar
TurboShed
Cossiemodo
Well I've just put the 071s in, gapped to 0.6 and the Cossie is all lovely again, purring like a lil ole kitten
Old Mar 24, 2006 | 05:23 PM
KSA-Cossie's Avatar
KSA-Cossie
Good stuff m8.
zvhrst
Ford Focus RS
16
May 26, 2007 07:02 PM
zvhrst
May 1, 2007 09:30 AM
