Garages
Old Jul 27, 2004 | 10:16 AM
stevo's Avatar
stevo
Default Garages
If they do work on ur car and break anything do they have to replace it??
i.e manifold studs?? having my gasket done soon and i no some are gonna snap, if they do do they cover the cost for new ones?
Old Jul 27, 2004 | 10:29 AM
Spiky's Avatar
Spiky
they probably fix it but charge you for their time,
in all fairness i think thats fine,
but
if they are doing a head gasket and put a hole in your rad, then they should fix it
Old Jul 27, 2004 | 10:43 AM
Oranoco's Avatar
Oranoco
If the manifold bolts sheer whilst removing to do a headgasket they will repair it but charge you which is fair enough as the job is related and they need to remove it to take the head off.
If the garage however was doing a headgasket and destroyed a starter motor (or in my case a gearbox swap that smashed my alternator in to its component parts ) then they should repair it with no charge to yourself.
Somthing about "Failing in their duty of care" I believe.
Old Jul 27, 2004 | 01:29 PM
soulweavers's Avatar
soulweavers
So you know, bolts shearing off that is classed as " work task problem " and chargable to customer ", if however undue force was used, then garage absorbs cost, now if damage to cars components, then garage is liable and insurance covers it.
Old Jul 27, 2004 | 01:31 PM
Spiky's Avatar
Spiky
you cant prove undue force
so yeah, they will charge you for failed bolts and
Old Jul 27, 2004 | 01:34 PM
stevo's Avatar
stevo
damn was gonna get some gold lated ones LOL.
what if the drill the studs out and crack the head???
Old Jul 27, 2004 | 01:40 PM
soulweavers
If even a small amount of the stud is showing the head can be heated up so it expands, thus a stud remover can be used, in 20 years in the motor trade then as a lecturer in motor engineering not once have I seen a head cracked through removal of studs.
Old Jul 27, 2004 | 01:42 PM
stevo's Avatar
stevo
god dam it man, pis on my fire wont u
gambo08
Feb 4, 2016 10:49 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
