S2 RS Turbo Bonnet raise question
Old Mar 4, 2006 | 09:48 PM
TIFF's Avatar
TIFF
Chasing Radders
Default S2 RS Turbo Bonnet raise question
If you raise the back of a S2 bonnet, and the bonnet does not shut down properly after..................
What do you need to alter???
Old Mar 5, 2006 | 08:41 AM
TIFF's Avatar
TIFF
Chasing Radders
Old Mar 5, 2006 | 08:43 AM
dave cos4x4's Avatar
dave cos4x4
slam it!
Old Mar 5, 2006 | 09:14 AM
©hatter Box's Avatar
©hatter Box
tiff are ur ones home made with washers
Old Mar 5, 2006 | 09:19 AM
TIFF's Avatar
TIFF
Chasing Radders
They are proper raiser block things if that makes sense
Its for Little Joes RS Turbo
Old Mar 5, 2006 | 09:25 AM
Daviet's Avatar
Daviet
i thought the bonnets on rst's were known for opening on there own with out the blocks.if i was to fit them id also want to fit bonnet pins aswell just for piece of mind
Old Mar 5, 2006 | 09:40 AM
Paddy's Avatar
Paddy
Legend
Its the catch at the front that goes into the slam panel, wiggle the whole bonnet round a bit with your hand on the release lever until it reaches.
Or if that doesnt work: on the catch on the bonnet, dab some tippex/white paint on the catch, drop it down and see where the paint ends up on the slam panel, thats where your problem is
Old Mar 5, 2006 | 10:15 AM
adamS2RST's Avatar
adamS2RST
Yea, they are ! Luckily I've never had it happen, but it can be major if it happens at speed! I'd personally pin it if I fitted blocks...(not that I would mind...)
Old Mar 5, 2006 | 10:16 AM
AndyRST's Avatar
AndyRST
Default Re: S2 RS Turbo Bonnet raise question
I would constantly worry that the bonnet would lift at 70mph for the rest of its life.
Seriously RST bonnets lift by themselfs without messing about with them, make DOUBLE sure its closing properly, and the catch is locking properly and the cable is well lubricated and doesnt stick.
Old Mar 5, 2006 | 10:25 AM
James Raby's Avatar
James Raby
It's the spring bit on the bonnet that causes these problems...
They get so rusty they cannot be adjusted...oil and grease them and you'll be fine, oh and the bonnet cable stretches over time so may be as well to check this where the catch is under the column - Checked mine yesterday and its bent :s
Tiff, you need to adjust the spring on the bonnet to make it shut properly
Old Mar 5, 2006 | 10:26 AM
Kop2381's Avatar
Kop2381
Adjust the front catch the part with the spring undo the locking nut and then with a flat screwdriver turn the thread accordingly
Old Mar 5, 2006 | 11:22 AM
NUTS RuS's Avatar
NUTS RuS
I'd fit a safety chain / lead inside to be extra safe if your worried about the components.
Old Mar 5, 2006 | 11:53 AM
Dan's Avatar
Dan
Tony Turbo has something set up to stop this Tiff, not that he's got bonnet blocks but he might be able to help Joe on the safety side of it
Old Mar 5, 2006 | 12:10 PM
Micky's Avatar
Micky
I have the same on mine.Its a steel cable jobbie!!Regards Micky
Old Mar 5, 2006 | 01:44 PM
Dan's Avatar
Dan
How does it work then Micky?
Old Mar 5, 2006 | 01:53 PM
Micky's Avatar
Micky
@ Dan,basically I have a steel cable that attaches to the underside of the bonnet.Its connected to part of the strenghtening sections of the bonnet that the skin is welded too.The other end of the cable has a karabiner on which I attach to the lifting hook on the engine.The cable is about 18 inches long.So if the bonnet gatch fails the bonnet open about 18 inches max and no more.
Click on the link to see what a "karbiner" is.
http://www.needlesports.com/acatalog...biners_22.html
Regards Micky
Old Mar 5, 2006 | 03:26 PM
Mark B's Avatar
Mark B
good idea mate
MB.,
Old Mar 5, 2006 | 03:28 PM
adamS2RST's Avatar
adamS2RST
I've got one on mine too
Old Mar 5, 2006 | 03:59 PM
Dan's Avatar
Dan
Regards Micky
Cool, I know what a karabiner is too mate, my mates into climbing! lol
Good idea though, worth while mod I should think!
Old Mar 5, 2006 | 04:00 PM
andre_k's Avatar
andre_k
i need one on mine...
i have had two bonnes fly up on me on mk4's... not pleasent
i always check the catch is closed before i slam her shut (my old cable had a kink that held the catch open), then i pull her upwards, just to double check... you can never be too careful!
i would go for pins, but i want to keep the standard look...
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
cossirob
Aug 31, 2015 09:53 PM
A.t.p
Aug 15, 2015 11:37 AM
Michael Wisbey
Aug 14, 2015 11:57 PM
