Anybody with S8 explain something for me please?????
How does it control exactly what psi boost is used????
I have a set of air injectors........
And I had a fooking good look at the boost duty mapping feature!!
BUT..... This is in percentages of injector open/closed at throttle position versus RPM.
Now this has got me confused (doesn't take much!!) How do you specify/control the boost level!!
As I know the air injectors can run 'indefinite' boost by staying shut!!
Is it anything to do with the size of the jet??
JK12
33
Apr 26, 2021 12:09 PM
Sheepdisease
Aug 30, 2015 09:11 PM
