cooling issues
Old Mar 2, 2006 | 07:42 PM
shane's Avatar
shane
Default cooling issues
When the cooling fans come in on my s2 they dont seem to take the temparature down much but just hold it steady. ive recently got a front mount and twin fans and sometime it takes the temp down so the fans go off is this normal as most cars the fans cut in and out but on my rs they pretty much stay on constant wen sat in traffic but they go off when driving.
opinions please...
Old Mar 2, 2006 | 07:46 PM
Paul17's Avatar
Paul17
Sounds about right 2me the engine get's hot when standin in traffic and then cools when drivin so the fan comes in when it gets hot n stops when the engine cools?
Old Mar 2, 2006 | 08:05 PM
Micky's Avatar
Micky
Its because you have a barn door sized cooler stuck in front of youre rad mate ,youre lucky the temp doesnt continue to rise even with the fans running.Regards Micky
Old Mar 2, 2006 | 08:09 PM
Paul17's Avatar
Paul17
you could always wire the fan up to the ignition so it's always on if ya want the fan on more
Old Mar 2, 2006 | 08:11 PM
shane's Avatar
shane
but i love that barn sized cooler
Also whats the normal operating temp for the thermostat, and what temp will the fans kick in on a standard switch?
Old Mar 2, 2006 | 08:17 PM
adamS2RST's Avatar
adamS2RST
Bad idea...
Old Mar 2, 2006 | 08:18 PM
adamS2RST's Avatar
adamS2RST
Standard thermostat opens at 88 degrees. Quite a common thing to do is fit a 82 degree thermostat and a cossie fan switch as it kick's in earlier IIRC. Oh and wire up a manual fan overide switch for when you are coming up to traffic
Old Mar 2, 2006 | 08:41 PM
addiction's Avatar
addiction
spot on
i have this set up with twin kenlowe fans and have no temp probs at all
Old Mar 2, 2006 | 08:45 PM
Davey8oy's Avatar
Davey8oy
i have bought an alloy rad and turbo cooler to try and cure this problem!
alot of peeps end up with 92 degree thermoststes!
i got sold one from fords before!
i got an 82 degree one from burtons for a fiver!
i see someone sellin em on ebay and they were fetchin 15 quid!
there is some mugs out there!!!
and some people earnin money
Mark_
14
Jan 16, 2016 05:27 PM
Chas
Oct 5, 2015 07:13 PM
SMILER258
Sep 28, 2015 09:04 AM
turbotrev
14
Sep 27, 2015 10:44 AM
pabloXR
Sep 21, 2015 12:42 PM
