Drilling a YB rocker cover for an oil seperator, where?.....
Old Mar 2, 2006 | 05:40 PM
churchy's Avatar
churchy
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
Default Drilling a YB rocker cover for an oil seperator, where?.....
Hi everyone,
Right, I have just removed my cam cover, and I have a couple of questions. I have to drill a 5/8 hole in it to take an alloy tube for an oil seperator pipe. I was led to believe that there is a certain place it must go, or where it was designed to go, namely in this cast hole, at the back where its arrowed...................
Now the problem with this is that where the hole would come out on the other side is right smack bang in the middle of where the cover is tapered to allow the clearence of the cams, so the pipe that I have to push on won't sit flush with the top of the cover. The blue vertical line illistrates where the hole would roughly come out....................
So basically, is this where the breather pipe has to go, or is it in the wrong place????
One other thing, what is that little hole for arrowed on the second piccy?
Thanks
Old Mar 2, 2006 | 05:42 PM
bud-weis's Avatar
bud-weis
Football Cwazy
yes that is where you drill
not sure what the little hole is for but don't think it does anything, maybe stops a bit of pressure/condensation building up in the hollow area around the spark plug chamber
Old Mar 2, 2006 | 05:44 PM
xr4x4rs's Avatar
xr4x4rs
thats where i had my one fitted for my breather system mate
and as far as i know its the only place to fit it
Old Mar 2, 2006 | 05:45 PM
markk's Avatar
markk
have you got any bigger pics tho - just before i tell you thats its correct
Old Mar 2, 2006 | 05:49 PM
churchy's Avatar
churchy
I know, sorry bout the pic size Thank the lord for autosizing on PF
So will I have to machine a flat on the top side so the hose sits flush???
Thanks for the feedback peeps
Old Mar 2, 2006 | 06:07 PM
Billabong's Avatar
Billabong
Churchy, you could always breathe from the exhaust side of the block instead of the cam cover....
Old Mar 2, 2006 | 06:12 PM
Rossco's Avatar
Rossco
Just leave the cam cover in ya front room, she will breathe well then mate!
Old Mar 2, 2006 | 06:32 PM
CosKev3's Avatar
CosKev3
Cut the hose on the same angle as the rocker cover if your that fussy m8
Can't really tell when its on the car anyway m8
Old Mar 2, 2006 | 08:05 PM
Graceland's Avatar
Graceland
Team HOTHOT!
i did a how-to guide Mike
its in the technical essay area
churchy's Avatar
churchy
I only just thought of that about 5 minutes ago
Cheers Kev
Ross...............
Shut up you tart
Cheers Paul
Steve Escos
Ford Focus ST Parts for Sale
Sep 2, 2019 11:39 PM
yatta
May 21, 2016 10:31 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
hopper350
Sep 4, 2015 12:53 AM
