fiesta body repair
Old Mar 2, 2006 | 05:38 PM
cocaina_xr2i's Avatar
cocaina_xr2i
wrench it all
Default fiesta body repair
how can tell me where can i get a a-pilar or what can I do to repair my a-pilar in my fezz mk3?
Old Mar 2, 2006 | 08:15 PM
jayRS's Avatar
jayRS
whats up with it? im not sure if they sell them tbh but you can and prob the only/easy way would be to cut one out at a scrappy mate.
am i right in thinking you wanna change it as yours has rotted out at the bottom?
Old Mar 3, 2006 | 12:18 AM
Philly_F's Avatar
Philly_F
becareful with doing that mate, if its bent or twisted leave it or get it repaired professionally.
if its rusted at the bottom, how bad is it? external internal? has a hole?
Old Mar 3, 2006 | 08:41 AM
cocaina_xr2i
wrench it all
yes it is rousted at the bottom and yes it does have one little hole the size of a 5p coin the thing that worries me is that mi windscreen cracked on me yesterday right from where the rust hole is so i was thinking of cuting the exterior bit of it and weld a new bit in its placeor even make a new bit out of a sheet of metal, about my skills there is not worries as I was a welder at my last job I have a good knowlaged of what I'm doing
Old Mar 3, 2006 | 12:06 PM
Philly_F's Avatar
Philly_F
cut it out then weld a plate in it matey, as for your windscreen cracking, not too sure if that would have caused it. is it defo in your a pillar and not in the scuttle?
Old Mar 3, 2006 | 02:44 PM
jayRS's Avatar
jayRS
the hole wouldnt make ya screen crack as the body would have to twist a fucking lot for that to happen and it it does, you got more to worry about than a rust hole mate!
cut the rust out, and plate it, easiest way to do it mate as its not worth fucking about with if its only that small, as long as the rust hasnt creaped round and rusted nearly all of it your be ok.
Old Mar 3, 2006 | 06:30 PM
cocaina_xr2i
wrench it all
Thanks for the advice guys thats what I'm gonna do and for the windscreen I've been told by my mate that it was the same kid that pused my car from the axel stands will post some pics of it asap
155lee
Sep 6, 2016 11:10 AM
mk1turboestate
Dec 2, 2015 08:31 PM
Andypandy260
Sep 23, 2015 10:28 PM
roomey
Sep 19, 2015 08:40 AM
KennyWelsh
Ford Focus (All Models)
Sep 13, 2015 08:28 PM
