Electrical fault on new shape tranny van ,,HELP PLEASE
Old Mar 1, 2006 | 07:21 PM
Mr RS500's Avatar
Mr RS500
Default Electrical fault on new shape tranny van ,,HELP PLEASE
Hi all
I have a new shape tranny van ( 2.4 td )
Drive along and then all electrics ( that are live through ignition ) stop working , windows / spedo / indicators / etc etc ,, everything that is wired perm live ( lights etc ) all wprk perfect ,
The van still runs perfect , but just no electrics at all
Any ideas please ??? I have changed the ignition switch with new but nothing
Ta ,Paul
Old Mar 1, 2006 | 07:32 PM
jon@work's Avatar
jon@work
ignition relay ?
Old Mar 1, 2006 | 07:33 PM
The DIVA's Avatar
The DIVA
Ignition relay....
Can`t remember which one it is though,should be in the manual...
Old Mar 1, 2006 | 07:42 PM
Mr RS500's Avatar
Mr RS500
I havent got a bloody manual
Will go to ford tommorrow and get one
Thanks
Old Mar 1, 2006 | 09:51 PM
cfoster's Avatar
cfoster
Have you checked the Control Unit behind the glovebox on the passenger side? It has a green and blue plug attached to it. Not sure exactly what each wire does but a lot of things run through it! Could be worth checking that its plugged in correctly etc.. (presuming its a 55 plate tranny)
Chris
Old Mar 3, 2006 | 02:03 PM
Dave Parker's Avatar
Dave Parker
my transit connect 54 plate did the same believe it or not but ifound if you hold the screen washers on for a few seconds the fault cleared until left over night it was a loose connection in the fuse box (wire)
Old Mar 3, 2006 | 04:26 PM
3drbadboy's Avatar
3drbadboy
BURN IT
Old Mar 3, 2006 | 04:32 PM
Dirty Harry's Avatar
Dirty Harry
Super Moderator
buy a Sprinter you tight git trannies are for pikeys
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
AJC
Oct 1, 2015 06:47 PM
stevecfrst1
Sep 30, 2015 05:18 AM
