Electrical fault on new shape tranny van ,,HELP PLEASE
Hi all
I have a new shape tranny van ( 2.4 td )
Drive along and then all electrics ( that are live through ignition ) stop working , windows / spedo / indicators / etc etc ,, everything that is wired perm live ( lights etc ) all wprk perfect ,
The van still runs perfect , but just no electrics at all
Any ideas please ??? I have changed the ignition switch with new but nothing
Ta ,Paul
Ta ,Paul
Have you checked the Control Unit behind the glovebox on the passenger side? It has a green and blue plug attached to it. Not sure exactly what each wire does but a lot of things run through it! Could be worth checking that its plugged in correctly etc.. (presuming its a 55 plate tranny)
Chris
Chris
my transit connect 54 plate did the same believe it or not but ifound if you hold the screen washers on for a few seconds the fault cleared until left over night it was a loose connection in the fuse box (wire)
