which way round should it be??? pump/filter
Old Mar 1, 2006 | 05:37 PM
M K's Avatar
M K
Default which way round should it be??? pump/filter
is it swirl pot, fuel pump then filter
or
swirl pot ,, filter then fuel pump
its a custom set up so not a particular cossie ect
Old Mar 1, 2006 | 05:40 PM
TheBishMan's Avatar
TheBishMan
I dunno lol
But the filter should go after the pump lol
Dont want no shit getting thru
Old Mar 1, 2006 | 05:43 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Fuel filter goes after the pump.
After the pump but before the fuel rail or metering unit.
Old Mar 1, 2006 | 05:51 PM
markk's Avatar
markk
to be perfectly honoust and more than correct is should be 'filter > pump > filter > swirl chamber > main pump > filter > engine'
by not doing the above cost me Ł400 a while back in two pumps
Old Mar 1, 2006 | 06:46 PM
Micky's Avatar
Micky
I agree with markk above,the filter should be fitted before the pump to protect it from cr*p etc.Regards Micky
Old Mar 2, 2006 | 06:35 AM
M K's Avatar
M K
ok i didnt think id bother saying all the rest but the exact set up will be,,,
jaz cell
filter
swirl pot
fuel pump
filter
rail
swirl pot
jaz cell
cheers
Old Mar 2, 2006 | 06:53 AM
markk's Avatar
markk
jaz cell
filter
swirl pot
fuel pump
filter
rail
swirl pot
jaz cell
cheers
your missing a pump pal , and i would use an extra filter in there as well.
Old Mar 2, 2006 | 09:59 AM
sbd16v's Avatar
sbd16v
yeh you also need a lift pump to the swirl pot
Old Mar 2, 2006 | 06:26 PM
M K's Avatar
M K
my mistake,,,did a treble shift,,,lol
the set up is
jaz fuel cell
fuel filter
facet lift pump
swirl pot
044 fuel pump
fuel filter
regulator
fuel rail
Old Mar 2, 2006 | 07:08 PM
markk's Avatar
markk
the set up is
jaz fuel cell
fuel filter
facet lift pump
swirl pot
044 fuel pump
fuel filter
regulator
fuel rail
Old Mar 2, 2006 | 07:24 PM
M K's Avatar
M K
got there in the end ,
cheers
timsrs
Nov 13, 2018 11:48 AM
gcfcos
59
Oct 6, 2015 05:04 PM
The Youth.
Sep 30, 2015 09:59 PM
DAZZER
Sep 30, 2015 08:43 PM
stevecfrst1
Sep 30, 2015 05:18 AM
