after starting a newly rebuilt cossie engine........
Old Feb 28, 2006 | 11:25 PM
stu21t's Avatar
stu21t
Default after starting a newly rebuilt cossie engine........
do i need to start it once then turn it off straight away, then come back to it the next day to re-tighten the headbolts?
is there anything i need to know or do after it starts for the 1st time?
Old Feb 28, 2006 | 11:40 PM
Doug's Avatar
Doug
Default Re: after starting a newly rebuilt cossie engine........
No you dont need to retorque run it up to temp make sure you have hot air in the car thru the vents and that all of the rad is hot then make sure fans cut in allow to cool check coolant and oil level top up if nessasary check over for any leaks
Job done bobs your uncle fannys your aunt and robert is very much your mothers brother not litterally lol .
Old Mar 1, 2006 | 07:37 AM
Stu @ M Developments's Avatar
PassionFords Creator
Douglas, stop giving out perfectly good advice and get your ass over to the Gatecrasher topic and sign up for this Saturday night, your dancing and social skills are very much required sexy. Over and Out.
Old Mar 1, 2006 | 08:43 AM
Butch.'s Avatar
Butch.
Make sure u leave the plugs out and turn it over till the oil light goes out check the oil level then put the plugs in and start it
Old Mar 1, 2006 | 08:58 AM
Butch, same goes for you!!
Old Mar 1, 2006 | 08:59 AM
stu21t's Avatar
stu21t
aye cheers peeps.
i know about that lot, its just the re-torqueing i was unsure of
fingers crossed
Old Mar 1, 2006 | 09:24 AM
As Doug said, stretch bolts dont require a re-torque, in fact, you didnt technically torque them down in the first place, you stretched them into their final position...
Old Mar 1, 2006 | 09:38 AM
And if you "retorque" them you will stretch them past where they should be, and risk a loss in clamping force.
And before you get on my case Stu, Im at a trackday this weekend so cant come, lol
Old Mar 1, 2006 | 09:42 AM
Damn.. i was on a roll then
What ya doing Sunday?
Old Mar 1, 2006 | 07:37 PM
Doug's Avatar
Doug
Stu my sweet sexy friend NOT IN A GAY WAY im also at a track day on sat otherwise I would have loved to of graced you with my presence
P.S. love u x lol
Old Mar 1, 2006 | 07:43 PM
PeterLucas's Avatar
PeterLucas
If its a fresh engine its a good idea to take the dizzy out and turn the 6mm hex to get oil pressure round the system before you even crank over without the plugs.
This is what i was told anyway
Adam-M
Aug 26, 2015 05:53 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
ekjim
Aug 17, 2015 08:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
