wireless help with pics..
Old Feb 28, 2006 | 07:54 PM
Westy's Avatar
Westy
Default wireless help with pics..
after being ripped by some coont off of ebay, I managed to get hold of this...
Now Im hoping Ive got it right this time... can anyone confirm that this is a roiuter/modem?? or will i need to link it to my existing thing..
When I put the BT disk in to set up the wireles connection, it should have
install BT wireless adapter on the menu, but it doesnt
Can anyone shed any light... I know this laptop runs wireless as round my dads house it works fine on his wireless setup..
thanks
Old Feb 28, 2006 | 07:57 PM
Rick's Avatar
Rick
u need to configure the router with ur adsl settings, u do this by plugging it into the ethernet port of ur laptop.
Old Feb 28, 2006 | 08:03 PM
Westy's Avatar
Westy
Rick
i currently have standard setup at the mo, wit the cable from the modem... (not wireless)
the lappy is WIfi if that makes a difference..
whats the best way to configure the router with my adsl settings?? should i leave this to the pro's?
cant be that difficult surely...
also could you confirm if what i just bought is all i need, or will i need to use the bt modem im on now as well??
thanks
p.s that question was right you brainy
Old Feb 28, 2006 | 08:12 PM
DanRSturbo's Avatar
DanRSturbo
Right lad, firstly, what the fuck is that ? Manufactirer and model number will do, or a better clearer pic.
To wire up the adsl modem, take the cable that run's from your phone line, and plug it into your router / modem thing you have just bought. Ensure that all the lights are on, then plug your ethernet cable into a spare port on the router / modem thing. into your network card on your pc. Then click on start -> Run and type in \\192.168.1.1 and it should open the router (check the manual for further instructions) You will need to setup the network name atc, encryption, etc and then do the same you your laptop / PSP etc that you want to connect it to.
Let this be a lesson to you.
Old Feb 28, 2006 | 08:21 PM
Westy's Avatar
Westy
fook this..
having cable isnt so bad after all.. Going to wait a while and chill out..
cheers Dan.. appreciate the help.. but network card.. my laptop doesnt have one.. it problably does just im not to sure what it is..
I thing my old man's mate knows a thing or two about wireless, so may just chuck him a few beers tokens.. its easier..
cheers #rick and Dan tho.. but I think this will piss me off
Old Feb 28, 2006 | 08:26 PM
Westy's Avatar
Westy
change of plan..
im going to do it tomorrow Ive re-read it and i actually now think i know what you mean
Old Mar 11, 2006 | 11:13 AM
Westy's Avatar
Westy
round 8
when i type that 192/168.1.1 the page comes up as this page will not load... you know the one, white screen, black text
this is how i have done it, so that the router can talk to the computer.. is
it correct please?
the grey cable goes to the laptop... i just put it into one of the 4 lines..
these are the lights which are on..
thanks
Old Mar 11, 2006 | 11:41 AM
Billabong's Avatar
Billabong
Westy, RTFM
The manual you got with the router should tell you the routers IP address, it isn't always 192.168.1.1 ......as Dan has already stated.
Old Mar 11, 2006 | 11:47 AM
Westy's Avatar
Westy
ive read the manual, and know it word for word
Click http://voyager.home to start your Internet browser and open the BT Voyager Configuration Manager.
If this address does not work, try http://192.168.1.1 instead.
this is what it says.. to be honest, i reckon ive been given the wrong disk, but dont quote me on that
i noticed it did sya restart, so will try that quickly... *
*bongman hopes it doesnt restart.,,
Old Mar 11, 2006 | 12:00 PM
Westy's Avatar
Westy
im back...
this is what i get on my screen...
and this is the screenprint in the manual...
Old Mar 11, 2006 | 12:06 PM
aduz's Avatar
aduz
with mine once i got into the router pge i put my sign on details in the router configured everything
Old Mar 11, 2006 | 12:07 PM
Westy's Avatar
Westy
aduz
thats the problem tho, i cant get into the router page
Old Mar 11, 2006 | 12:08 PM
aduz's Avatar
aduz
Originally Posted by Westy
aduz
oh cant help yer then
i know b4 i managed it i had to "repair the connection"
Westy's Avatar
Westy
Old Mar 11, 2006 | 12:10 PM
aduz's Avatar
aduz
edited above for more useless info
Old Mar 11, 2006 | 12:13 PM
Adrian's Avatar
Adrian
Firstly, I would click on the user guide and read.
secondly, I would then click on the installation guide.
Failing that Westy, google the model of router you have and see if anyone else has had issues with wireless setup.
Old Mar 11, 2006 | 12:16 PM
Westy's Avatar
Westy
thanks..
i have read it tho ade, maybe im just useless at this stuff.. no patience and get pissed off..
i did noice this
You must install a compatible 802.11g or 802.11b wireless adapter on all computers you want to connect to your wireless network.
the laptop has wifi, so havent touched anything.... it ran fine on a wireless connection elsewhere
Old Mar 11, 2006 | 01:42 PM
Stu.H's Avatar
Stu.H
if u was closer id have a look 4 ya, wireless rocks
looks like u have all the right lights, maybe make sure u have the same ip range/subnet on ur network card.
go to network settings, set the ip of the network card in machine to 192.168.1.10 and the subnet to 255.255.255.0
then try browsing to http://192.168.1.1
hth
Old Mar 11, 2006 | 02:11 PM
DanRSturbo's Avatar
DanRSturbo
Westy,
All you have to do is setup the wireless network
Old Mar 11, 2006 | 02:12 PM
Billabong's Avatar
Billabong
So, your ADSL works fine through the router (albeit wired)
You need to go into your wireless configuration on your laptop to connect to the router. You'll still need to sort out security settings on the router though. I'll hazard a guess that your dad's wireless network isn't running security....
What model no. is your router and what laptop, what operating system?
http://www.voyager.bt.com/faqs/wireless_index.htm
Old Mar 11, 2006 | 02:16 PM
Stu.H's Avatar
Stu.H
its a 2100 bill u can see from the pic
i was wondering if wireless dhcp waqs set as standard. mind you if only one device is gonna be connecting then a bridge so to speak would be fine anyway.
Old Mar 11, 2006 | 02:19 PM
Billabong's Avatar
Billabong
Doh! didn't scroll right
http://www.voyager.bt.com/faqs/wirel...xp/2100faq.htm (assuming you're in this century and running XP )
Old Mar 11, 2006 | 05:56 PM
Westy's Avatar
Westy
cheers lads
nicorsts1
Aug 6, 2005 12:51 PM
Turbo lag
Sep 6, 2004 06:57 PM
