Compression Stutts
Old Jul 26, 2004 | 12:55 PM
JohnnyB's Avatar
JohnnyB
Default Compression Stutts
Gentlman
What are the advantages on compression strutts over standard anti roll bar setup
Thanks in advance
Old Jul 26, 2004 | 01:44 PM
JohnnyB's Avatar
JohnnyB
UP
Old Jul 26, 2004 | 01:54 PM
Tony Ryan's Avatar
Tony Ryan
Johnny ,
its a relatively complicated subject so forgive that most people wont have time to reply . If these are for the car in your sig , a roadcar , then dont bother , you will not feel any benefit unless you replace the existing roll bar with a forward facing GpA style one . The only benefit you may get is to adjust the castor position of the front legs , this will give you "turn in camber " only for pointy slow corner entry , something that only on track will you feel . If there is a special reason that you want these it would help to know it .
cheers
Old Jul 26, 2004 | 01:55 PM
JohnnyB's Avatar
JohnnyB
cheers mate thanks for taking the time.
Tar.
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
