turbos....how to pick one.... any1 know anything about VNT?
Old Feb 27, 2006 | 10:28 PM
stu21t's Avatar
stu21t
Default turbos....how to pick one.... any1 know anything about VNT?
i know that a lot of reno 5 people run a VNT in T28 size and love em,
but i know a lot of tuners who dont like em and say they are no good, but the people making them say they are great.
how do you know who to believe?
how do you pick your turbo?
i like the idea of a vnt and believe that it will be the next generation of turbo especially as porsche now use them as std but are the current garrett ones good enough? or will the GT series be better?
but theres sooo many different trims, wheels, housings... how do you pick the best one.
i know some1 who builds turbos whos says that the GT series arent much better than a standard T series and VNT are the ones to get,
i just dont wanna go and spend loads of money on a turbo only to find out i could have got one better suited to me
i know most will say to use what the person building the engine wants to use, but if they havent tried a vnt or a certain type of turbo they wont know how it performs.
Old Feb 27, 2006 | 10:38 PM
MK5RST's Avatar
MK5RST
what engine ??? what spec??
Old Feb 27, 2006 | 10:45 PM
stu21t's Avatar
stu21t
say a 4/500bhp cossie
Old Feb 27, 2006 | 10:47 PM
big difference between a 400 and 500 bhp cossie TBH
Old Feb 27, 2006 | 10:48 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
The problem with VNTs are two fold.
High exhaust gas temp seems to fuck them up too quickly.
Setting up the VNT mechanism to work ideally for your car (if it not the standard car the turbo came off) can be a pain in the arse.
Lots of types of VNT turbos, from teeny T2 sized ones to mahooooosive VNT GT40s which look the tits.
Companys like Holset etc also make VNT turbos.
GT turbos are more modern than Garrett T-series ones, but they seem to use thinner shafts in many cases, which makes them slightly weaker.
Most people who has done back to back testing has said to stick with the normal journal bearings too, as the BB cores seem to be weaker, more expensive, and dont seem to noticably help perormance.
And seeing as you dont HAVE to have a BB core on a GT turbo, well...
Many aftermarket turbo companys use a mixture of components, GT, T, and their own designs, to make their ones, so something being called a T or GT summat if its not made by Garrett dont nececerily mean loads.
Working out sizing of turbos is down to wheel and housing sizes compared to engine spec (mainly capacity and working rev range).
But far too long winded to talk about here, when can read about it all over internet.
Give a detailed spec of what car its for and what you want from it, and might be able to help.
Old Feb 27, 2006 | 11:07 PM
stu21t's Avatar
stu21t
well at the mo im only thinking about them.
just trying to get some info on them
the problem is im not sure on the power of the engine.
ideally i want a 500/550bhp cossie engine (dont we all) if money allows but at the mo i have what is supposed to be a 400 bhp engine (not ben run yet so dont know but was told it was built for 400bhp.)
its going to be used for 1/4m, track days and sometimes on the road
i know i should wait till i have the engine i am going to settle with but its just something ive been thinking about.
i know turbo technics are building a T38 sized unit at the mo, they say it will be finished around june time and when its ready it will have a 2 year garentee.
a 2 year garentee is good enough for me really.
and it would have an external wastegate and ecu controlled boost
do you know of any sites i can read up on them? whenever i type vnt into a search engine it comes up with useless crap. lol
Old Feb 27, 2006 | 11:08 PM
stu21t's Avatar
stu21t
also do you know any websites that sell vnts? i can never find em??
Old Feb 27, 2006 | 11:39 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
VNT's are not widely available commercially, mainly due to them not waning to take the risk of tons of warrenty cases caused by mis-use.
Ebay is the place to be, esp Ebay america, been a fair few VNT GT40s on there recently, never mind smaller ones.
IMO unless your an expert (dont seem like you are) and got money to burn experermenting (dont seem like you have) id stick with conventional turbos.
What spec is your current engine? Built for 400bhp dont mean much.
Old Feb 28, 2006 | 06:28 AM
Badman38's Avatar
Badman38
sorry if i sound stupid but what does vnt stand for?
Old Feb 28, 2006 | 07:23 AM
Nick_RSIFEZ's Avatar
Nick_RSIFEZ
"Very Naughty Turbo" sorry!! i know nothing!
Old Feb 28, 2006 | 07:30 AM
Personally i wouldnt ever want to run a VNT turbo on a petrol car that doesnt have an airflow meter of some sort.
The way the pumping losses of the engine change means the ignition and fueling requirements change too, on something like L8 you would have to make some assumptions about how the VNT side of things was operating and that to my mind is dangerous.
Old Feb 28, 2006 | 07:35 AM
stu21t's Avatar
stu21t
i dont know the spec of my current engine. but i will try and find out
im no expert as you can tell and i definately dont have money to burn.
i will have to think about it.
unless one comes up really cheap i wont bother then.
theres loads of names for VNT, VVT, VGT, but basically mean the same thing,
Variable, Neutrane/Vane/Geometry, Turbo/Turbine,
basically they mean that you can run a larger exhaust housing and run less spool up times due to the vanes.... they will change the size of the rear housing
it starts off small to spool up quickly then the vanes move and the housing gets larger.
Old Feb 28, 2006 | 07:37 AM
It coming up cheap doesnt make it any more likely to not cost you a fortune knackering your engine when the vanes dont move at the rate your ECU expects them to!
Old Feb 28, 2006 | 07:39 AM
stu21t's Avatar
stu21t
the car will be on new management, just not sure which one yet.
im starting to get put off now. lol
Old Feb 28, 2006 | 07:41 AM
On your new management, how will the ECU know the vanes have moved?
Who is going to map it for you?
In the world of cossies you are unlikely to find anything cheap or easy to do that yields gains that others arent already doing as there are so many people out there developing these engines still.
Stop and ask yourself why no one else is using one on a cossie, is it cause none of the cossie tuners have heard of a VNT turbo? or is it cause they know how much cost is involved in developing one to work properly versus how little gain is involved?
Old Feb 28, 2006 | 07:45 AM
stu21t's Avatar
stu21t
thats why i asked on here
cos i havent heard of any1 using one.
but i know R5 people who do. i know its different but worth asking about.
depends what management i buy as to who maps it.
so i could be the person to try it and find out its the best thing you could do to the car,
or the exact opposite. lol
Old Feb 28, 2006 | 07:48 AM
ok, best of luck, let us know how you get on.
Old Feb 28, 2006 | 07:52 AM
stu21t's Avatar
stu21t
lol i doubt i will end up trying it, theres not enough people saying yes go for it, but more people saying no dont.
Old Feb 28, 2006 | 07:59 AM
You seriously need to think about how the ECU is going to know whats going on with the vanes.
Daft as it sounds, the R5 essentially is an airflow based system, cossie is only normally map and TPS
I dont see how map and TPS can really work with a VNT turbo in a high state of tune.
Old Feb 28, 2006 | 08:09 AM
Jay,'s Avatar
Jay,
Sponsor
stu man for christ sake lol if you want proper answers then give more details
cheers jay
you sold ur 21 then by the way
Old Feb 28, 2006 | 09:40 AM
BMEP's Avatar
BMEP
That is a good point.
The way I understand it, the variable vane position within the Exh housing will be governed by the Exh gas back pressure, agree? If so, then wouldn’t that mean that the pressure within the intake manifold would govern the Exh gas back pressure dependant on engine rpm?
I would have thought that it would be correct to say that by mapping the engine using a map sensor (rather than an airflow meter) would be more accurate considering the above?
In my opinion the most accurate method would be using TPS/MAP/Exh back pressure “mode”. The Autronic ecu range do offer this option in there software.
I’m interested in opinions as this is a discussion that I have yet to see/read on the net
Old Feb 28, 2006 | 09:46 AM
The problem is that the VE of the engine is not fixed at a given RPM/Boost level anymore because it will also depend on the vanes, thats my objection.
Now obviously in theory the vanes should always do the same thing at any given rpm/boost level, but in reality i suspect that the different time to go up through the gears will result in a slightly different response at any given load site from the vanes, especially as they are not instantaneous to react.
However, If you measure exhaust back pressure then thats cool, you just need some sort of feedback in terms of what the vanes are doing so you can use that to alter the fuelling, then you dont need an airflow meter signal, that was just one suggestion on how to react to the vanes.
Old Feb 28, 2006 | 10:02 AM
BMEP's Avatar
BMEP
Yes totally agree. The vanes would react much slower that what the electronics in the ecu/engine dynamics would. If there is a Exh gas back pressure input to the ecu, I would have thought regardless of vane position that the ecu would compare Intake manifold pressure VS Exh gas back pressure to give an indication of vane position (to a degree).
By knowing the approx vane position (hence Exh back pressure) VS engine rpm/manifold pressure I have no doubt that it is possible to tune. The amount of time taken though would be immense considering every possible scenario
Personally I’d prefer to stick to my “conventional” style of turbo too
Old Feb 28, 2006 | 10:05 AM
Yes i agree, you can do it on exhaust back pressure without a problem.
And im not even sure it needs to take very long as you could probably keep it safe just by doing it as an adjustment that worked on a % basis of whatever load site you are in, assuming you had an ECU that allows you to do so.
The problem of course though, like you say is that it would be quite involved to map it to REALLY take advantage of the variable vanes by keeping the fuelling and timing spot on to make sure the engine performed to its optimum, which is obviously very different to just keeping it safe like i mention.
I guess this is why they only tend to appear on diesels normally!
Old Feb 28, 2006 | 10:20 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Some cool VNT pics, different sizes and designs...
Old Feb 28, 2006 | 10:21 AM
BMEP's Avatar
BMEP
Yes, as you mentioned above the problem would be whilst in a steady state of load/rpm whilst the vanes haven’t yet “stabilised” as this would cause variations in fuel/ignition delivery. Admittedly depending on load/rpm the difference could be negligible to some what concerning.
As mentioned, if the ecu is also using Intake manifold pressure vs Exh gas back pressure to add/subtract Ign/fuel to the base fuel/Ign tables then it would be well sorted
Old Feb 28, 2006 | 10:22 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Oh, BTW, even though people think the new Porsche is the first, here was the first proper production PETROL car that used a VNT (IIRC)
http://cgi.ebay.com/ebaymotors/Dodge...spagenameZWDVW
Old Feb 28, 2006 | 10:43 AM
BMEP's Avatar
BMEP
Itsmeagain,
Cheers for the pics
Old Feb 28, 2006 | 10:44 AM
I quite like the look of those cars, never been in one though
But they handle wank though, being american!
Good pics steve
Old Feb 28, 2006 | 11:29 AM
AlexF's Avatar
AlexF
Nope... diesel EGTs are aboout 600 degress C MAX!
A fair bit less than a petrol running lambda 1
Alex
Old Feb 28, 2006 | 11:43 AM
Alex, does the temperature kill the VNT mechanism off then?
Old Feb 28, 2006 | 11:51 AM
AlexF's Avatar
AlexF
yup...
it makes it stick.
We had problems running turbos very hard when I was at Ford... the 2.0 puma (diesel engine not car!) use to stick and stay stuck!
Alex
Old Feb 28, 2006 | 11:54 AM
Its definately sounding like a seriously bad idea on a highly tuned petrol engine the more you look into it!
Old Feb 28, 2006 | 12:26 PM
no1girlracer's Avatar
no1girlracer
Which of the turbo suppliers is running a twin vnt set up on a 4x4 sierra, i cant remember who it is, it was at pod ???
Old Feb 28, 2006 | 01:55 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Turbo Technics 24v hillclimber runs VNTs yea, have done for last 8yrs or so IIRC.
Old Feb 28, 2006 | 02:23 PM
RWD_cossie_wil's Avatar
RWD_cossie_wil
VNT is used on jet engines across many different applications, so I can't see the temps of a turbo causing too many problems if its built correctly
Whilst I don't know a lot about the applcation of VNT on turbochargers etc, I can't see the general principles of the systems operations being massivly different, and on aircraft engines the VIGV and VNT (on the compressor and turbine respectivly) are used mainly at lower engine speeds, to try and smooth out the power delivery and stop surging due to bad airflow through the engine as it accelerates.
As far as I can see, the VNT on a car turbo would be used for the lower RPM range, to give extra responsiveness on a larger turbo, so top end performance mapping shouldn't be a problem as the VNT on a turbo should be in its fully open position as soon as the turbo is on full boost, and the lower end operation is controlled by the ratio of manifold pressure to the exhaust pressure, so to control the fuel map etc a decent closed loop lambda system should control it quite happily.
Old Feb 28, 2006 | 03:21 PM
stu21t's Avatar
stu21t
as far as im aware the reason for them sticking is that they were taken straight off a diesel engine and not designed directly for a petrol engine, therefore not prepared for the petrol heat,
also the soot produce in a diesel engine wont help.
jay i would give more details if i had them but i mafraid i dont, and no i havent sold the 21 or any other car. lol
as RWD says the vnt only really does its thing lower down the rev range, to help with spool up.
once on boost surely it wouldnt change the backpressure??????
if it can be asfely controlled during lower boost levels (while spooling up) with lamba, backpressure sensor, exhaust temp sensors....
then it has to be worth a try, how else will any1 find out?
Old Feb 28, 2006 | 03:26 PM
If they are always fully open before you go out of closed loop, then yes i should think its a pretty straightforward thing to implement, and if the whole of the section of the map you are going to be open loop on is mapped for them open then it would only run rich if they closed anyway i should think, so sounds a nice safe way round, my worry is having a point on boost thats mapped for them shut and then they open.
Old Feb 28, 2006 | 03:32 PM
stu21t's Avatar
stu21t
well i guess i need to speak to some mappers and turbo suppliers a bit more before going ahead.
if an external wastegate was fitted then wouldnt that limit the boost it would produce so not much fear of it spiking
also a pop off valve could be fitted at 1 or 2 psi above the desired boost level for safety,
plus if it was mapped for vanes closed but they opened then surely the egts would go down and the ecu could react??? same vise versa to
