a bit of help please....
Old Feb 27, 2006 | 06:27 PM
fordsportjay's Avatar
fordsportjay
Default a bit of help please....
ive got a 4x4 cossie that i bought as a runabout for myself.its started playing up in that sometimes it takes a long time to start,then splutters for a bit when you try to rev it up as if its holding back-then sometimes it will clear,or it will stay like that and when you try to drive it,it holds back on acceleration then pulls as it should-as if something is clearing.
ive changed the dist cap/rotor arm/leads.the phase sensor is in good cond.ive tried a map sensor,changed the blue temp sensor,fitted a new inlet man gasket,tried another coil and ign amp.
when it doesnt start it stinks of fuel as if its flooding,but there is a good spark there.
ive checked all the wiring and it all seems fine-would the crank sensor cause such a fault as i havent tried that yet.
its strange as it all seems to have happened since my lad fitted a breather kit to it last weekend,but i cant see anything disturbed/broken.
may be a coincidence.....to say its doing my head in is an understatement-
any ideas anyone........i thank you all in advence
oh yes its supposed to be stage 1 chipped,closed loop map by norris,but thats what i was told....
Old Feb 27, 2006 | 07:02 PM
fordsportjay
surely someone must have an idea?
please.
Old Feb 27, 2006 | 07:11 PM
Sticky.'s Avatar
Sticky.
Defo worth trying the crank sensor, knock sensor and also the surpressor on the coil to.
Old Feb 27, 2006 | 07:14 PM
The DIVA's Avatar
The DIVA
Charge air temp sensor....
Old Feb 27, 2006 | 07:24 PM
fordsportjay
ill try them all tomorrow,but havent got a spare knock sensor
why do i have all these probs with a 4wd 52000 mile car when all my 2wd ones give me no hassle.....
robbie-the l8 has landed ,with air injector driver,brum,brum soon(hopefully)
Old Feb 27, 2006 | 07:33 PM
The DIVA's Avatar
The DIVA
Cool matey.....
Give us a shout if you get stuck on the 4x4 and i`ll cast an expert eye over it..
Old Feb 27, 2006 | 07:57 PM
Stu @ M Developments's Avatar
PassionFords Creator
Does the rev counter do anything unusual?
Old Feb 28, 2006 | 08:32 AM
fordsportjay
actually the rev counter doesnt seem to move in a flowing sweep,like its juddering.do you know what it could be stu?
Old Feb 28, 2006 | 08:35 AM
Poor connections in the Plugs on the bulkhead are common, strip and clean out, do NOT use some garbage like WD40, this will make them worse.
Old Feb 28, 2006 | 09:18 AM
fordsportjay
that sounds like a possibility stu as he was struggling to mount the breather in the usual place as the loom was in the way.whats best stuff to use to clean it-i have some good quality brake cleaner
Old Feb 28, 2006 | 09:36 AM
fordsportjay
looking good,the plug with all the smaller wires has been held together with a cable tie and the connections look a bit dirty.seems to be running better now,just a bit lumpy on idle,but revs up freely.ill clean it properly and secure it and take it out for a run.....many thanks to everyone again-
this is the best,most helpful site i have ever used.well worth Ł20
Old Feb 28, 2006 | 09:44 AM
gingeRS's Avatar
gingeRS
good to see you got it sorted
Old Feb 28, 2006 | 09:53 AM
fordsportjay
hopefully-fookin cossies
why do we do it
TPM961
Jan 15, 2018 10:50 AM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
chowfornow
Sep 19, 2015 10:47 PM
