General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Dont attempt to cut down one that is too long as you may end up with not enough threaded hole and/or no adjustment left.......I know someone that tried this once
Sounds like the 60mm one Phil
There are some that around 75mm and i may have one somewhere. Will that be long enough?
Alternativly you could do as has been suggested above
