how to remove the wire from a wire rang block .
.had a block wire rang.a few years ago and the wire is looking a bit flat its only welding wire that ther how do u get it out any tips
Done mine this weekend all i done was knocked it out with a small screwdriver but you will find its not welding wire as welding wire is copper coated steel you need pure copper as welding wire will not squash down and will not let the head seal hope this helps
Originally Posted by abdr500
so how do you get the wire out then .i know how it works so .just need to know how to remove or best way to
find the end of the wire USE a scalpel type screw driver and tap it gently with a hammer
my engine had these and i couldn't get them to seal properly.
firstly if the grooves in the block are not perfect then it wont work anyway. secondly there will inevitably be a gap where the wire ends meet. gasket keeps blowing.
finished up machining the block to get rid of them (30 thou) and using different pistons to get comp correct. avoid at all costs!!
If done correctly it is fine and works very very well,
if you've had them before people and had problems i think you would do better looking at how it was done rather than the actual idea itself?
Lee
Lee
Lee
Lee
Lee
Lee
my engine is wire wrung and im sure martins will be too
[quote="pgt"]my engine had these and i couldn't get them to seal properly.
the ONLY way that could happen WOULD be if the person doing the job DOESN'T know what he/she is doing m8!
YOU CAN NOT USE A METAL TYPE HEAD GASKET WITH A BLOCK THAT'S BEEN WIRE WRUNG DUE TO IT NOT BEING ABLE TO SEAL
Tib
You must just be lucky as everyone i know who had this done had big problems with it ,I raced cars for 7 years so new a lot of people ( inc myself ) who payed out a lot of money to have this done and didnt even get a full season before it destroyed the head and block of there engines .
How many motorsport people ( and i mean proper motorsport people) not them who think 2 blasts up a strip is motorsport still use this ???
Paul
Paul
well... that comment was mine and you're right i didn't know how to do it properly. but thats the point, why not just use a decent gasket and bin the whole concept of wire rings
[/quote]
so because YOU didn't know how to do it properly that makes it a crap idea
I've known many people that have and still do use this dependant on which application the engines being used for!
decent head gasket??? name me any make of gasket that IS 100% fail prove!
[/quote]so because YOU didn't know how to do it properly that makes it a crap idea
Originally Posted by NORTH YORKS RS SPARES
Tib
Paul
Paul
my saph's spec with the gas on was more than some wrc spec gaskets seem to be able to handle too.
Anyway its horses for courses as they say and i and anyone i know thats done it have been satisfied with the results
Hi Peeps
I had a wire rung 200 block yrs ago with grp a gasket (yb 0611)
when i was on the greens i did 38,000 mile in 5/6 yrs which included track days ..1/4 mile days and general road abuse
never had a problem what so ever
there is better things out there for the cossie now like the wrc gaskets or cometics , but with these you have to make sure the block and the head is totally flat (slightly skim the block and head job done )
marco
marco
Originally Posted by marco polo
Hi Peeps
marco
marco
lee
i don't think you will have a problem to be honest , it's just when the wrc gaskest was made (mountune)rally and race engine builders went this route instead ( instead of the wire ring )
i know yrs ago that all the race team use to use wire rung blocks
thats was the only way at the time keep the head gasket in place with out it popping and the other route was coppers rung block you had the choice of 2
but just because something comes out that is newer doesn't mean that old stuff is not as good
Marco
Marco
I know what your saying but i'm just wary of the standard gaskets fire ring actually being a strong enough metal to withstand the extra heat that the nitrous gives??
this was my last metal gasket, i'm not saying it was gasket failure alone as i think it was something else that caused it to go but you can see the way the gas eats anything in its path lol
Wire rings are like Coopers rings..FINE if everything else is absolutely spot on...if not then big money...crap idea to use nowadays with the likes of cometics etc....my block has had the wire rings machined out...SCS done this....My experience with coopers was disaster..LOL.
Ive had 2 wire rung HT racing engines in 2wd Cars, both on 205 blocks , both were fine and ran a pinto or std cos head gasket up to 2.0bar . As soon as i added a T4 tho , all fkin hell let loose , the wire blew out the side of the block , destroyed the head and dropped valves into pistons , big mess ! Long studs and Coopers rings or a WRC gasket now !
to me its an age old idea that was the best that could be done at the time, the wires were lifed of a good power motor , only ever seen 18months work out of one in road trim, in race trim , i wouldnt even entertain it, ever.
as for a gap ? WTF - there is no gap if there done properly.
so how do you join the ends of the welding wire together to get rid of the gap?
