Clutch maybe?
Old Feb 27, 2006 | 08:53 AM
BM's Avatar
BM
Default Clutch maybe?
Recently ive noticed the car over revving ( )
Its a mk5 facelift 1995 escort 1.6 16V
And I pull away in 1st, into second and into third..
Im in third & I put the boot down a good bit & the car seems to rev more than pull
My mate said to "test" the clutch.. I should park with handbrake on & select 1st & let the clutch go beyond the biting point. I did so & it was pulling the car & eventually stalled!
Ideas?
Old Mar 1, 2006 | 05:46 AM
johnnvs's Avatar
johnnvs
sounds more like a gearbox fault to me mate if its ok in all other gears.
Old Mar 15, 2006 | 11:04 AM
BM's Avatar
BM
Ever since this post, Ive noticed my biting point getting hight and higher
Is the clutch on its way out? or can you tighten it?
Im utter piss with cars so dont laugh at me
Old Mar 15, 2006 | 12:29 PM
David Ramsey's Avatar
David Ramsey
Might be the clutch but they aren't very much for your engine if you just want a bobby basic
Old Mar 15, 2006 | 01:31 PM
SafeChav's Avatar
SafeChav
Sounds like the clutch to be honest, just drive along in a high gear and floor it and see if the rev counter moves round more in proportion to the speedo than normal, should be fairly easy to tell.
Biting point getting higher and higher could suggest the clutch or the self adjuster on the pedal. See if its slipping first.
Old Mar 15, 2006 | 01:38 PM
David Ramsey
Should easily be able to get a clutch for about £50-£60 for this
BM's Avatar
BM
Yeah, when driving in 1st, 2nd, 3rd, 4th etc and I go to speed up it revs more than it pulls
Clutch then?
How much for a clutch?
Old Mar 15, 2006 | 01:39 PM
BM's Avatar
BM
Cheers David
How long to fit it (garage)?
Old Mar 15, 2006 | 01:42 PM
SafeChav's Avatar
SafeChav
Sounds like the clutch then. As David Ramsey said the clutches for these are 10 to a penny but its going to get expensive when you have to pay some other monkey to fit it. It would be worthwhile putting a new clutch pedal quadrant and pawl on the clutch pedal aswell, as they are prone to wear/breaking.
Old Mar 17, 2006 | 05:02 PM
David Ramsey
Can't remember how much I paid to get my clutch fitted exactly but it wasn't as much as the clutch. I took it to a local garage owned by an rs fanatic and he done it for me.
Old Mar 17, 2006 | 05:24 PM
SafeChav's Avatar
SafeChav
All i can really say to that then is that must of been one expensive clutch cos theyre 10 to a penny for a standard RS clutch, like £30 for a complete kit!!!!
Old Mar 24, 2006 | 11:04 AM
BM's Avatar
BM
It hasnt got any worse.. not booting it around though so hopefully it should hold out for a few months
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
