how much work have you lot done on you cars this winter
and whats the next bling thing for this summer to have,,,,,, powder coating tanks was last year
whats the one this year then lads
Still doing work on mine to get ready for the ring trip.
fitted coilovers,secs monitor,paddle clutch,polybushes,engine mounts,alloy bits,quick shift,new rocker cover and gasket,strut brace.
think thats it.
got to do all the rear,polybushes,powder coating etc....
nothing bling really ,i just want the car to be good on road and track.
might get to drive it wen finished,only had the car 7 weeks and done bout 30 mile in it.
think thats it.
From: Out Shooting Burgelers, cause thats what Norfolk people do!!!
I have done lots and lots, it started with needing just a new turbo, then I thought about some new suspension, and bushes, and wheels, and brakes, and an oil breather, and a spot of powder coating, and thats all I can afford
Next big thing will be 2 YB's welded together to make a V8 cossie
I have had some paint work done on mine got rid of a shnoky aerial in the back wing also new front bumper /splitter fitted.
Also change loads more standerd bits replaced with new gen ford new items.
PS.
would have done a bit more if some ginger chap will get to the post office
PS.
Originally Posted by b19bal
its been posted matey,,,,,,,,, seriously has as i sent it upstairs to admin on friday and they franked it to be sent,,,,,,, well it wasnt there saturday anyway
In no rush mate TBH where you sent it work or home address
Havent done alot to be honest
Been short on the benjamines!!! Have purchased a quickshift, lowering springs, samcos, group a coil, rouse splitter, refurbished rocker cover...oh and travelled nearly 600 miles for a cracking leather interior
Engine rebuild, headwork, new gearbox, new oil cooler, new dizzy, new fuel system including lines, pump and filter, new altornator, new heater matrix, new gauges, quads fitted............ breath............ just about to have two plates welded ready for respray, final live mapping session sometime in march then show time
Been a busy winter
Been a busy winter
this winter has been pretty busy.
solid mount rear beam, all new nylon trailing arm bushes, 3.9 rear diff, gearbox rebuild with 3.9 step off gears, adjustable TCA'S, bigger front brakes, stack dash... but then sold it again
DONE:
Poly bushed rear end
fuel pump rewire
engine bay multi plug replace.
painted a couple of bits up.
Still TO DO: (starting next weekend)
Engine out and re-build!
Poly bush front end
bit more painting/powdercoating to make bits look nice
new turbo and re-map after running in
all in time for me to enjoy it for the summer!
fuel pump rewire
Poly bush front end
during winter i:
changed oil twice (too cold for the 10w40 stuff up ere, so went to 5w30)
ripped out my chav guages (could change display colour on em)
put in new ones
fixed me bootlock (erm, change that to broke boot lock
fitted some serious ICE (headunit, sub, amp, ps2, screen)
got it setup (got thru 2 fuel pumps, 1st one faulty...needed new phase sensor, plugs, dis cap n rotor arm)
bought nice shiney rs500 cooler, fitted it too
all i need to do is take care of rust, buy 4xtyres and tax it!
put in new ones
)fitted some serious ICE (headunit, sub, amp, ps2, screen)
JoeyBoyden
Jan 4, 2024 02:36 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
