740 hp ford sierra cosworth
Old Feb 26, 2006 | 11:15 AM
RS500's Avatar
RS500
Default 740 hp ford sierra cosworth
Anyone heard is this cossie and tuner.
And it's also a high comp cosworth engine whit loads of power.
Engine: RS500 block, RS500 studs, CPS (silicone processed) pistons 91mm, RS500 rods, Polished head derived from the 4x4 model, mechanical rocker arms, last-stage Kent camshafts for mechanical rocker arms CW8. Adjustable Kent camshaft gears. Valves are bigger by 0.5mm, covered with titanium EP-371. 6-litre oil pan. Lightweight crankshaft and flywheel. 2-disc AP Racing clutch. Pectel T6 electrics. 8.5:1 compression ratio. Turbocharger is a mix of KKK and Garrett T72 compressor with 100/72 wheel. The intercooler is the one used on the RS500. The car uses an aluminum radiator and a MOCAL oil radiator as well. The dump valve is made by Bonalume and the external waste-gate comes from the Audi RS2. There are 8 fuel injectors in total with a flow of (4x475cc)+(4x1000cc). WRC gasket.
Exhaust: 90mm pipe.
Suspension: Height-adjustable Bilstein groupA dampers, polyurethane silent-blocks.
Transmission: Gearbox with modified ratios, diff ratio is 3.9:1. 75% limited slip differential.
Brakes: TAROX 6-pot calipers, 321mm disks at the front. Larger disks on the rear.
Other Info: The dyno showed 740bhp and 68 kilos of torque @ 7500rpm with 2,2bar ct and 2,5bar overboost. 0-100 in 3,3secs.
http://www.extreme-tuners.com/projects.html
Old Feb 26, 2006 | 11:23 AM
Munch's Avatar
Munch
Mr. Sparkle!
what a monster
Old Feb 26, 2006 | 11:30 AM
Niall.b's Avatar
Niall.b
thats a bit of a turbo
Old Feb 26, 2006 | 11:41 AM
Mr.T's Avatar
Mr.T
That is sick.
Old Feb 26, 2006 | 11:53 AM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Looks good.. but??
0-100 in 3,3secs.
Old Feb 26, 2006 | 11:54 AM
Dan's Avatar
Dan
0-60mph (100KPH) is bastid quick for anything let alone a RWD 3dr!
Anymore pics, I wanna see the wheels and interior!
Old Feb 26, 2006 | 11:55 AM
Charlie Chalk
Unknown.
Oh ok
RSCossieGaz's Avatar
RSCossieGaz
from the front it starts as a sappy then ends as a 3dr
turbo_boost's Avatar
turbo_boost
Whats up with teh front of the car ????
Old Feb 26, 2006 | 11:56 AM
Charlie Chalk
Unknown.
whats wrong with that??? been a few like it
Old Feb 26, 2006 | 11:57 AM
Dan's Avatar
Dan
Originally Posted by turbo_boost
Whats up with the front of the car ????
Been converted I should think mate For the worse IMO BTW! lol
Rhys's Avatar
Rhys
Seen this car a few months ago on here. 3dr with Saff front bumper confuse's the fook out of me when i frist look at it
Old Feb 26, 2006 | 12:03 PM
turbo_boost
Agree mate looks odd
Old Feb 26, 2006 | 12:04 PM
Dan's Avatar
Dan
I didn't notice to begin with Rhys, then had a double-take on it!
Old Feb 26, 2006 | 01:02 PM
Ollie.'s Avatar
Ollie.
0-100 will be kilometers per hour..... eg 0-62mph.......
still dubious about the time though unless it has big FAT slicks lol
Ollie
Old Feb 26, 2006 | 01:24 PM
peteh's Avatar
peteh
it's the lights aswell though so therefore the wings will have to be changed to take the saph indicators, plus it's a 4x4 bonnet
sure it aint photoshopped?
Old Feb 26, 2006 | 02:13 PM
COSSIE CAL's Avatar
COSSIE CAL
a saph front end on a 3dr that luks mint!!!
Old Feb 26, 2006 | 02:18 PM
KSA-Cossie's Avatar
KSA-Cossie
Monster fookin turbo,imagine the laaaaaaaaaaaaaaaaagggg !
Old Feb 26, 2006 | 02:28 PM
peteh's Avatar
peteh
and the surge
Old Feb 26, 2006 | 02:42 PM
Pez71's Avatar
Pez71
If you notice, its left hand drive, the Sierra Mk 2 (Sapphire type) was available on mainland Europe as a three door model
Old Feb 26, 2006 | 03:10 PM
peteh's Avatar
peteh
what they available like this saph front/3dr rear?
Old Feb 26, 2006 | 03:15 PM
Pez71's Avatar
Pez71
Its just a three door Mk 2 shell, check out the pic below. There are some in Britain, very popular among the FSOC members
Old Feb 26, 2006 | 03:56 PM
wimwerf's Avatar
wimwerf
what's a rs500 rod...isnt that the same as all the other cossie rods...
is a cossie rod good for 700+ bhp....
Old Feb 26, 2006 | 05:06 PM
robrs2's Avatar
robrs2
Who hasn't got a mk2 3door this is mine
Old Feb 26, 2006 | 05:57 PM
Staffi's Avatar
Staffi
It looks shit
Old Feb 26, 2006 | 06:27 PM
photon1's Avatar
photon1
Never even knew they existed!
Old Feb 26, 2006 | 06:29 PM
jacko's Avatar
jacko
most are imports i had a red one
Old Feb 26, 2006 | 07:01 PM
RS500's Avatar
RS500
Soon the have escort cosworth whit 800-850 hp.
Those crazy greeks.
Old Feb 26, 2006 | 08:50 PM
Mr. G's Avatar
Mr. G
Great car mate . But I thought rs500 and 3dr had the same rods and block(205). Am I wrong?
What kind of gearbox does it use, if T5 what kind of internals
Old Feb 26, 2006 | 09:25 PM
dave cos4x4's Avatar
dave cos4x4
big turbo, but not sure on the body.
Old Feb 26, 2006 | 10:02 PM
T4KAF's Avatar
T4KAF
quick is it!!lol!!!
Old Feb 26, 2006 | 11:48 PM
twitchyrear's Avatar
twitchyrear
MONSTER turbo on that
Old Feb 27, 2006 | 04:50 AM
Seen quite a few like this when i have been about in europe ,that turbo is HUGE
Old Feb 28, 2006 | 08:03 AM
rsjonesy's Avatar
rsjonesy
nice turbo but i not to impressed with the body
Old Feb 28, 2006 | 04:25 PM
wimwerf's Avatar
wimwerf
everyone is looking for the turbo....but a cossie rod can't take that power...or am i totaly wrong...
great spec btw..
Old Feb 28, 2006 | 05:38 PM
James-W's Avatar
James-W
Cos mate a standard cosworth rod can handle around 700-720bhp with a safety factor built into that so at a push it may handle 740 but running on that boost and compression ratio it will probably not handle 2.5 bar boost on 8:5:1 it will be on race fuel.
The RS500's were homologated for touring cars so may have stronger internals so may be stronger but the blocks are not stronger than 200 blocks a common made mistake.
Cant say the engine will last long on standard rods, crank and a not linered block.
Been around ages this car but will only have the boost turned up at meets/when showing off on race fuel and tbh will be down on 1 bar boost most of the time even if it is drove on the road.
No hard feelings on the owners if this sounds threatening but Im just trying to state the truth.
Old Feb 28, 2006 | 06:24 PM
Porkie's Avatar
Porkie
RS500 rods are the same as normal cossie rods. The rods are VERY strong as is the crank. The only problem is they are heavy and so you don't want to be slinging them around at much over 8000rpm.
Cool car some of the spec doesn't add up though... and there is NO way it could do 0-62.5 mph in 3.3 seconds in my view.
Old Feb 28, 2006 | 09:22 PM
COSSIE CAL's Avatar
COSSIE CAL
how could i get a mk2 3ddor people???
Old Feb 28, 2006 | 09:37 PM
kouzman's Avatar
kouzman
Extreme Tuners is a Greece based tuning shop. The setup you posted is their very old one. Obviously they haven't updated their website yet.
The car is 4wd now and for a while it ran a HKS T51R KAI turbo pushing 717 at the wheels....
Currently they running in a new engine (VERY HIGH spec) to push probably a GT42R turbo (probably more than 800 at the wheels)
More info soon... (maybe you will see it in a very known british ford mag when the car is ready....)
Old Mar 1, 2006 | 08:46 AM
Mr.Ford's Avatar
Mr.Ford
sick
