1800 pulley and CPS
Feb 26, 2006 | 11:14 AM
1800 pulley and CPS
where can i get one?
Feb 26, 2006 | 05:56 PM
Feb 27, 2006 | 03:00 PM
yea, but finding a sierra - theyve all disolved...
Feb 27, 2006 | 03:36 PM
I've got one you buy off me
You will also find it a lot easier if you get the cam cover aswell as thats what the sensor mounts onto.
Feb 27, 2006 | 03:44 PM
Feb 27, 2006 | 03:46 PM
Well i have pulleys and CPS's, and i can get the cam cover for you aswell. The cam covers are cast alloy but the norm is to cut the bottom half off so u can still run a normal cam cover (or none at all if u dont run one)
Feb 27, 2006 | 03:47 PM
pm me a price for all the bits then mate
Feb 27, 2006 | 03:52 PM
I have no idea really i'd say PM me an offer?? You do realise though how rediculously close to the chassis rail the pully sits yeah? And also you will need to change the pulley on your alternator, get a 1.8 alternator bracket and a different alternator belt, and lastly (mine isn't on EFI yet so i cant confirm) but im 99.9% sure you have to drop the engine mount to do a cambelt change?
Feb 27, 2006 | 05:09 PM
i thought that u had to machine the pulley down?
Feb 27, 2006 | 05:15 PM
field motorsport looked into using this on mine but decided against it for some reason
thats all i know im afraid
Feb 27, 2006 | 05:48 PM
im using one that was machined down
i can get the pulley and belt off without taking the engine mount off
Feb 27, 2006 | 06:48 PM
jano is ur best bet rick
Feb 27, 2006 | 06:50 PM
Feb 27, 2006 | 07:10 PM
cool - Jano u recommend this method on Mfi block?
Feb 27, 2006 | 07:11 PM
Its what Twins runs on his, i dont know about machining the pulley though theres not a lot you could machine off???
Feb 27, 2006 | 07:19 PM
we have the set up on fayes cabrio and works a teat
i got 2 other cvhs i got to sort out with the 1800 set up jano got all the bits u need
Feb 27, 2006 | 07:24 PM
Is there anything different about what jano sells?
Feb 27, 2006 | 08:10 PM
I have a machined pulley with the 36-1 teeth or whatever it is
Think this is a good way of doing it ?
Feb 27, 2006 | 08:45 PM
It will work fine just can be a bit annoying come cambelt change time...
What is machined about it? Any pics
DixieTheKid
11
Jun 6, 2020 11:20 AM
Nov 1, 2015 06:53 PM
dombanks
Sep 21, 2015 08:38 PM
biggiejody
Sep 19, 2015 10:25 AM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
