Ipods
Old Feb 24, 2006 | 10:53 PM
OldSkoolRS's Avatar
OldSkoolRS
Default Ipods
I'm looking at getting an Ipod but I've heard that you can't run more than one from the same pc.
Is this true as my mum has one and I don't want to shell out £130 notes if I can't use the bloody thing!
Old Feb 25, 2006 | 09:28 AM
Mr S1's Avatar
Mr S1
Don't ask - I don't know
I had a problem with this as I originally bought a mini then a Nano. Different tracks on each and it got a bit confused..............solved the problem as use PC for the Nano and laptop for the mini !!!
Old Feb 25, 2006 | 05:14 PM
OldSkoolRS's Avatar
OldSkoolRS
anybody else?
Old Feb 25, 2006 | 05:37 PM
89xr2's Avatar
89xr2
Brap!
You can use as many as you want because itunes loads up the ipod and its all clearly named at the side. Just set itunes so that you update your ipod manually and all is good. I often stick my mates on my pc and put a load of my music on them.
Old Feb 25, 2006 | 06:41 PM
Tas662's Avatar
Tas662
Same here
Old Feb 25, 2006 | 09:09 PM
Andy-R's Avatar
Andy-R
True ITunes relates to the Ipod its registered to.
http://www.redchairsoftware.com/anapod/support/
The above software will sort you out...free trial..Its that good I purchased it!
dojj
Aug 25, 2015 06:56 PM
Mr S1
May 26, 2006 11:05 PM
gingeRS
Dec 10, 2005 02:01 AM
