NEW THERMOSTAT QUESTION
Old Feb 24, 2006 | 08:44 PM
rizla's Avatar
rizla
Default NEW THERMOSTAT QUESTION
Can anyone give me some advice?
Bought a new thermostat last week for my Escort cos big turbo, fitted it on car But bottom hose and bottom of rad was not getting hot.
So I fitted the old one back and the bottom hose got hot.
I took the new one back and they changed it, fitted it on car tonight and the bottom hose is not getting hot again! The bottom of rad is cold too. This is after running car for 45 minutes.
Put both thermostats in a saucepan of boiling water and the new one took alot longer to open, never opened as much as the old one. The new one closed a lot quicker than the old one. Do you think this is another faulty stat?
And yes, when i fitted the stat to the car I put the top mark to the top of housing
I only decided to change the stat because my temperature gauge was sitting higher than normal.
New temp sender fitted from Woodfords.
New fan switch
new ect sensor
and I have flushed all the system.
So I don't know what to do now
Do I take it back and say its another faulty stat?
Thanks for any advice
Old Feb 24, 2006 | 08:49 PM
andre_k's Avatar
andre_k
could it be head gasket? as to why the temps were higher originally?
prob wrong though
Old Feb 24, 2006 | 08:58 PM
rizla's Avatar
rizla
prob wrong though
We did think that at one time but im not loosing no water and none into the bores because the plugs look fine.
With the old stat fitted, car starts fine, drives lovely no mis fires, the only thing the temp gauge is sitting just over half way. When I bought the car it used to sit a quarter of the way up off the blue. Now fans dont cut in till the needle reaches the black line under the red. The oil pressures reading a quarter of the way up when this happens, but when you open the bonnet theres no major heat coming from the engine bay.
Any other ideas?
Old Feb 24, 2006 | 09:01 PM
haz87's Avatar
haz87
You sure you've got the exact same stat. Cause theres usually different temperature stats you can buy
Old Feb 24, 2006 | 09:05 PM
dave cos4x4's Avatar
dave cos4x4
but why would the first one alter temps from a 1/4 to 1/2.
you could put the first one back in then see what happens from there.
Old Feb 24, 2006 | 09:20 PM
abdr500's Avatar
abdr500
sounds like the temp reader is faulty had this befor
Old Feb 24, 2006 | 09:21 PM
rizla's Avatar
rizla
Yeah it is mate i had numbers check as well by DOO
Old Feb 24, 2006 | 09:26 PM
rizla's Avatar
rizla
It started going to halfway one day when i was driving in Januray and thats why i thought the stat was knacker so i thought if i change it it will take it back down again but with the new stat bottom hose and rad dont get warm and it still sits half way
I dont no mate getting well fed up now
Old Feb 24, 2006 | 09:28 PM
richm's Avatar
richm
What temperature is the coolant ACTUALLY running at? (seeing as you say there's no appreciable heat coming from the engine bay, and the fans appear to come on and off as they should..)
You are basing all your temperature readings on the notoriously inaccurate coolant temperature gauge..
Old Feb 24, 2006 | 09:29 PM
rizla's Avatar
rizla
Not sure mate as i say it was sitting higher before we change it
but this wood not cause the stat to open
Old Feb 24, 2006 | 09:39 PM
rizla's Avatar
rizla
How can i test what the engine is running at ?
All i know is this is my second big turbo Escos the temp gauge all ways sat a quarter of the way up on driving and the fans would cut in about half way in traffic
and the same on my old one
Then all of a sudden one day the temp gauge was sitting on the half way i thought this dont seem right And then the next time i took it out on motor way at night the weather was well cold i was doing about 80mph and the temp gauge was just over half way and thats why i started changing these bits to see if it would cure it
Old Feb 25, 2006 | 05:21 AM
rizla's Avatar
rizla
No other ideas what it might be
Im going to put the old stat back because i no that one makes the bottom hose hot and take it to Paul hills and get the head gasket checked
I want to get it rolling road but because of the temp i dont want to take a chance
Thanks for replys
Old Feb 25, 2006 | 07:28 AM
MATCOS's Avatar
MATCOS
Hope you get it sorted rizla, I hoped that someone would have an answer incase this happens when I put my new stat in
Old Feb 25, 2006 | 09:24 AM
richm's Avatar
richm
Rizla, you need to know what the temperature of the coolant coming out of the stat really is (thermocouple or similar slipped inside the top hose), the gauge/sender are notoriously unreliable (although in most cases changing the sender like you say you have usually fixes that...) IMO the bottom hose being cold with the new stat is a red herring and kinda suggests to me that the old stat is opening too early and letting coolant flow round the rad earlier than it needs to, warming up the rad with "warm" water. Are these tests being done with the car standing, or after a drive (to get proper heat into the engine and coolant)?
Mine will sit on my drive running from cold for ages without the fans running, in this cold weather I fancy they may never come on, the rad is sufficient to cool the water enough in these conditions, engine idling on the drive.
The stat should be open around 88-92deg.C to let water into the rad, that is way too hot to hold on to with your hand - if you can hold the top hose with the old stat when it is open, then it is open too early at to low a temperature.
I keep emphasising your reliance on the gauge indication of temperature - mine used to sit at about 1/4 on the gauge all the time, from 5 minutes after the engine started until the fans came on, which is obviously nonsense, periodically it would go up over halfway then come back again while driving... - just illustrates the unreliability that's all I'm saying. Changing the sender did fix this by the way, so that it reads mid way normally, and a tad higher when the fans cut in.
Old Feb 25, 2006 | 10:52 AM
Dicko&Vacant's Avatar
Dicko&Vacant
ive had exactly same prob before, turned out to be a faulty thermostat
Old Feb 25, 2006 | 10:54 AM
Stu @ M Developments's Avatar
PassionFords Creator
Ford's YB stats are crap the past few years, tend to run teh engine around 94degrees. We no longer use them.
Old Feb 25, 2006 | 11:27 AM
richm's Avatar
richm
where do you get them from instead Stu?
Old Feb 25, 2006 | 12:33 PM
330cossie's Avatar
330cossie
The test me and rizla have done are with the car idleing in his garage,
Both stas have 82.c on the bottom of them which is i assume the temperature that they are ment to open at, but the new one he got
from ford's is opening later than his old stat,we put both stats in a
sausepan and watch them both to the boil and the new stat only
opened right near to the boiling where as the old one had fully
opened by then which make's me think that they are a bad batch
of thermostats ford's are supplying or as stu has said there crap.
What ive suggested to rizla is we put the old stat back in the
car and go for a good drive in it putting it under load and normal
driving and see where the car s temprature is at!
Old Feb 25, 2006 | 12:47 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
Old Feb 25, 2006 | 01:16 PM
Daveyraveygravy's Avatar
Daveyraveygravy
I have also heard that the thermostats from ford are crap too.
Old Feb 25, 2006 | 06:31 PM
rizla's Avatar
rizla
Thanks for advice
Cheers Roy mate
Old Feb 25, 2006 | 07:12 PM
rizla's Avatar
rizla
Originally Posted by Stu @ M Developments
Ford's YB stats are crap the past few years, tend to run the engine around 94degrees. We no longer use them.
PM sent
Old Feb 25, 2006 | 07:18 PM
rizla's Avatar
rizla
Can any one tell me why the 4X4 stat is a lot more than a 2WD stat in price
Old Feb 25, 2006 | 07:42 PM
330cossie's Avatar
330cossie
Rip off no other reason,when you compare
an escos thermostat with any other there is no
difference in it that would justify charging Ł40+
for one and say Ł7 for the other.
Total rip off
Old Feb 25, 2006 | 07:50 PM
330cossie's Avatar
330cossie
I have heard though rizla that some people use mondeo
thermostats in there escos as there an identical size and
fit yet cost a hell of a lot less,dont not what temperature
there set at though,im sure some people off here have
used them!
might be worth an ask
Old Feb 25, 2006 | 08:01 PM
Totally different stats, thats why.
2wd
4wd
Old Feb 25, 2006 | 08:02 PM
rizla's Avatar
rizla
richm What do you mean
Old Feb 25, 2006 | 08:05 PM
rizla's Avatar
rizla
[quote="Stu @ M Developments"]Totally different stats, thats why.
Stu are these not the Ford ones
Old Feb 25, 2006 | 08:26 PM
330cossie's Avatar
330cossie
Still a rip off
Old Feb 25, 2006 | 08:28 PM
rizla's Avatar
rizla
Stu i just look at my new Ford one and its different to yours
So what makes your one better than the Ford ones
Old Feb 25, 2006 | 08:31 PM
Mate, your 4x4 one should be almost EXACTLY the same as mine, the key point being the secondary disc. If yours looks like the top (2wd) one, hes given you teh wrong bloody one anyway
I agree, they are a ripoff indeed. But hey, not a great deal we can do about that eh?
Old Feb 25, 2006 | 08:32 PM
Mine really does open at 82degrees
Old Feb 25, 2006 | 08:45 PM
330cossie's Avatar
330cossie
Stu, rizla's stat is nearly the same looking as your 4x4 one.
How much are the one's you use and do you supply
them?
cheers Roy
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
The Enigma
Sep 29, 2015 10:31 AM
