fao any top speed guru's (i.e final drives techs)
Old Feb 23, 2006 | 05:46 PM
M K's Avatar
M K
Default fao any top speed guru's (i.e final drives techs)
im running a 1.6cvh roughly gonna be around the 280-300bhp mark (dyno next month)
on greys with t34 .63 housing
ive had my gearbox completely rebuilt with the following
im running standard rs turbo 1st to 5th gears with a 3.33:1 final drive
evidently the final drive i have is rare as rockin horse shite ???
what top speed will be capable from this gearing do you think??? im aiming for fastest mk2 (well its something to aim for)
Old Feb 23, 2006 | 06:14 PM
Tell us the 5th gear ratio & the tyre/ wheel info & we can tell you
Old Feb 23, 2006 | 06:16 PM
gus's Avatar
gus
i would just aim to get it finished at the mo mark
Old Feb 23, 2006 | 06:48 PM
M K's Avatar
M K
5th gear is standard rst i think???
wheel/tyre - 15x6.5j - 195/45/15
coming from you
Old Feb 23, 2006 | 07:53 PM
M K's Avatar
M K
Old Feb 23, 2006 | 07:55 PM
Benn 304R's Avatar
Benn 304R
coming from you
touche
Old Feb 23, 2006 | 08:12 PM
MadMac's Avatar
MadMac
Basing it on your final drive and standard RST gear ratios for 1st to 5th and your rolling radius from your wheel
Gearbox mans gear ratio calculator is the best ever
Old Feb 23, 2006 | 08:28 PM
M K's Avatar
M K
excellent mate
some potential for a good top speed run then
cheers
Old Feb 23, 2006 | 08:29 PM
MadMac's Avatar
MadMac
3.33 is a shorter ratio by the looks of it. So I think you will get a lower top speed at max revs.... but you should get there a bit quicker instead!
Old Feb 23, 2006 | 09:12 PM
M K's Avatar
M K
according to above chart
6.5k - 165ish mph
that'l do
Old Feb 23, 2006 | 09:13 PM
MadMac's Avatar
MadMac
fair play
Old Feb 24, 2006 | 06:23 PM
M K's Avatar
M K
but remember the xr2 is not the most aerodynamic car lol or the most stable at 140 +
Old Feb 25, 2006 | 12:54 PM
James-W's Avatar
James-W
Hope you reach your goals mate.
Old Feb 25, 2006 | 12:57 PM
gus's Avatar
gus
coming from you
touche
yeah well you smell of wee
Old Feb 25, 2006 | 02:23 PM
Fast Guy's Avatar
Fast Guy
If you know all your ratios etc, try this.
http://www.quaife.co.uk/downloads/QSpeedCalc.exe
Old Feb 25, 2006 | 02:56 PM
gearboxman's Avatar
gearboxman
Personally, I think you'll struggle to get the engine into its sweet spot with gearing that tall.
Top speed is all about power versus aerodynamic drag/frontal area.
Having said that, I've just input some rough data regarding this exercise into my Cartest2000 simulator, and it tells me I'm wrong......
Just for the record, the simulator shows a top speed on the 3.82 F/D as 154mph, whereas it gives 168mph on the 3.3 F/D.
Be interesting to see your results
mgtkr1
107
Dec 6, 2016 04:23 PM
matman
Sep 9, 2015 05:45 PM
Bailes1992
Aug 16, 2015 07:14 PM
gingerturbo
Aug 11, 2015 09:44 PM
fatboy billy
Aug 3, 2015 08:34 AM
