What coil overs can you get for saff 4x4 cossie???
Originally Posted by Nick b
Does anyone have prices???
Also bilstein said they do not do them???? aswell as koni
Nick b
Nick b
Gaz 475
AVO 500
Leda ??
Originally Posted by wimwerf
but isn't it you have to modify the chassis for some coilovers (i was told the rear end)
I personally think that poorly specced coil-obers are the worse thing you could add to ANY Cosworth. Ruins the ride quality.
when i bought my car, the previous owner said it is neccessary to modify the rear chassis, but said he hadnt doen it as he didnt wanna ruin the car
he described it as opening the rear turrets??
is this neccesary, i'm running AVO coilovers and the rear can seem a little creaky and squeaky at times
The only thing that you need to do is "modify" the nearside inner wing with a fuck-off big hammer
, as the spring always seems to rub this side (but not the other) on every single Cossie with coil-overs. This will be the creaking you can hear. If you look, you will see a shiney area worn away where the spring has been rubbing (and making the creaking noise). Hit this with big rubber hammer to "shape" it, and then grease the spring for good measure. Job done.
, as the spring always seems to rub this side (but not the other) on every single Cossie with coil-overs. This will be the creaking you can hear. If you look, you will see a shiney area worn away where the spring has been rubbing (and making the creaking noise). Hit this with big rubber hammer to "shape" it, and then grease the spring for good measure. Job done.My GAZ rears creek like mad aswell but on closer inspection it is actually the inside of the coil on the spring catching the damper body itself
What would cause this ??
Worn bushes, faulty shock ??
Anyone got any ideas what this may be as the coilovers dont seem to have caught on the bodyshell anywhere
Sorry Chris, I should have adequately clarified that this is on the REAR only with these clearance problems.
Mike my rears dont catch the body but do catch on the inside of the coil with the outside of the damper ??
Any ideas what may cause this ??
. Re-read it - ALL Cosworths do this...
Its weird because ive looked up at rear strutt and there is no sign of rubbing (only on the inside of the spring) ??
Ill check again though
Its the right hand side is that the correct side ?
Nearside = passenger side
If you read my post, I clearly say it is the spring that rubs on the body of the inner wing
Not on the body shell but on the spring itself...
The body of the shock is catching on the inside of the spring and there is no visable signs of it catching on the bodyshell itself
Originally Posted by Graceland
Avo on mine, nice firm ride, not too harsh aswell
last time i owned them they were Gaz coilovers.
i stand corrected
- i have Gaz coilovers on mine, and very nice they are too
As Mike says, modification to the inner arch is required, and on mine it took quite a bit of persuading with a hammer. Just painted up and greased and all has been well sinse.
PS - Mine are AVO's.
Anutternutter
Aug 21, 2015 06:07 PM
mrmann
Aug 20, 2015 11:24 PM
155lee
Aug 14, 2015 11:21 AM
